Old 05-09-2013, 08:43 PM   #1
i heart square bodys
i heart square bodys's Avatar
B&M lock-up controller 700r4 & cross member question
okay im having some slight issues here. im in the middle of swapping from a th350c to a 700r4 in my '86. the tranny is an 88 trans out of a truck. i have converted it from electric speedo to mechanical. i bought one of those B&M lock up controllers for it and the instructions are good to say the least. i am having issues with the 4 prong plug in the side. when i look down inside it on the tranny there are 3 connectors in the plug out of the 4 prongs, but inside the plug that came with the kit there are only two connectors(for prong A & D), there is a provision for another connector, whats the deal with this? do i just plug it in and hook up the 2 wires (supply and ground) ? or is there something i have to do with this third prong(prong B)?
now for the crossmember... do i have to drill new holes in the frame for this ? it is kind of looking that way to me but i thought id ask anyone with experience.
thanks to anyone that can help !
here are the instructions for the controller http://static.summitracing.com/globa.../bmm-70244.pdf
1986 LWB c10 w/327 & vortec heads
i heart square bodys is offline   Reply With Quote
Old 05-09-2013, 08:53 PM   #2
clinebarger
Re: B&M lock-up controller 700r4 & cross member question
Wire it the way the instructions say to.
Should not have to drill holes in a '86.
clinebarger is offline   Reply With Quote
Old 05-09-2013, 08:55 PM   #3
so dis regard B ? and maybe a stupid question but shouldnt the brake light switch supply power ? not cut it ?
Old 05-09-2013, 09:11 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
cause you want the lock up off when using the brakes
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 05-09-2013, 09:21 PM   #5
So the brake light switch cuts power to the trans?
Old 05-09-2013, 09:41 PM   #6
clinebarger
The TCC side of the brake switch will, The brake light side of the switch is opposite.
Old 05-09-2013, 10:40 PM   #7
ahhh okay i think i understand everything here now ! thanks guys sorry to me a major pain in the ass lol come to think of it now that i know how this works i likely could have made my own lock up switch
700r4, 700r4 swap, lockup, trans, transmission
