Old 10-03-2016, 09:03 PM   #1
Mrturner1
Holley fuel leak
I think I found another contributor to my carb issues lately. It's a brand new 750 dp so I don't know why it would be leaking but it is. It's leaking from the very front, where that little arm is that presses on the carb to shoot more fuel, by the red spring. Sorry it's my first Holley I have no idea what it's called lol
Mrturner1 is offline   Reply With Quote
Old 10-03-2016, 09:05 PM   #2
Mrturner1
Re: Holley fuel leak
Here's where it's coming from
Old 10-03-2016, 09:06 PM   #3
Mrturner1
Under this corner
Old 10-03-2016, 09:11 PM   #4
firedemon
the accelerator pump try and tighten the screws if not need new pump
firedemon is offline   Reply With Quote
Old 10-03-2016, 09:20 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The diaphragm itself seals the pump as it is sandwiched between the pump housing and the fuel bowl.
Just check to see if the screws are a tad loose. Don't get crazy and over tighten them. You strip out a hole and you're in for a new fuel bowl.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 10-03-2016, 09:31 PM   #6
Mrturner1
Gary
Cool thanks you guys I'll check it out and report back.
Old 10-04-2016, 11:32 AM   #7
davepl
davepl's Avatar
Check the gasket if it still leaks after tightening, could be folded or torn. If the gasket is fine and it still leaks, likely the diaphragm as a guess.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
