Old 02-08-2014, 06:36 PM   #1
IronAnRkst
Custom Console
So, here is my problem..
I am wanting to build a custom console in my 83 Scottsdale with a bench seat. I have my design figured up but my issue is other than making a resin mold of the floor hump does anyone have any other ideas as to getting the angles right..?
Where my hump is it has a lip along the bottom and back which I plan to sit the console down on then fiberglass coat but trying to come up with a better way to get the shape to follow the humps lip and go all the way around the curve of the bottom of the dash.. Any help is appreciated. Thanks.
IronAnRkst is offline   Reply With Quote
Old 02-11-2014, 09:00 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Custom Console
maybe cardboard?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 02-11-2014, 09:16 PM   #3
silverbear
silverbear's Avatar
Re: Custom Console
A guy I met a few years ago who did custom speaker boxes told me to cover what ever shape I wanted to match with aluminum foil. Make sure to secure it well . Then lay in a sheet of fiberglass cloth and apply the resin. Once it hardened, remove it from the shape and then add some more layers of cloth and resin to thicken up the panel.
I tried this once. After making my first layer, I cut some wood strips and glasses them along the edges as I was thickening the base. This gave me something to attach the side panels to.
Hope this helps or at least gives you some ideas.
86 Chevrolet K10 350/SM465 Frankie SOLD
1995 GMC Yukon GT SOLD
1996 GMC Yukon GT
2010 Suburban 1500 4x4 5.3l/6L80e. Sold
2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e
silverbear is offline   Reply With Quote
Old 02-12-2014, 12:45 AM   #4
mrolds88
Re: Custom Console
They make the plastic wrap (think kitchen) that has one side that will stick. Press and seal I think they call it. I would use that on the floor pan.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 02-12-2014, 09:56 AM   #5
1981Stepside
1981Stepside's Avatar
Re: Custom Console
I would use something a little stronger. Remember, during the curing process fibreglass gives off heat. More than enough to melt plastic wrap. Aluminum foil or a layer or two of painters tape is the way to go. Just remember to coat it with a light film of car wax as a release agent before the resin and matting go down.
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
