08-02-2014, 10:17 AM | #1 |
20x9 front wheels
I am looking to run a 20x9 front wheel with a 245/40/20 and a 20x12 rear wheel with a 315/35/20 on my 49 truck. The rear is not a problem but the front I am concerned about with rubbing. I am running a TCI Mustang ll with drop spindles and air ride. I really need some input on this. Has anyone run this 20x9 front wheel and what offset is used?
08-02-2014, 02:39 PM | #2 |
Re: 20x9 front wheels
I'm running a 22x9 with a 5.50 BS with some 5/8 shorter tubular control arms. The wheels fit in there pretty well cause I have rubberbands for tires and the control arms suck the wheels away from the fenders. That's going to be the biggest issue is your choice of tire I believe. If you go with some crazy backspace on the wheels that'll be another issue to contend with...
Long live SLIM ------------------ At least try to buy American |
08-02-2014, 09:54 PM | #3 | |
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
08-03-2014, 07:20 AM | #4 |
What is the back spacing or offset on the 20 x 8.5?
Are the control arms stock? Do you happen to know the hub to hub detention? If not what year front clip did you use so I can look it up. Thanks. |
08-03-2014, 04:43 PM | #5 | |
Stock control arms Front clip - 1982 to 1988 (I think) Marc
08-07-2014, 07:18 PM | #6 |
Hey Marc,
Where is yours rubbing?? Heres what I found. Hopefully this will help someone else looking to use 20 x 8, 8.5 or 9 front wheels The 78-88 G body front clip is 58-1/2 hub to hub The 47-55 1st series Chevy truck is 58-1/4-1/2 My 49 3/4 ton is 58-1/8 hub to hub 8 lug TCI's mustang ll , air ride 2" drop spindles, wilwood 11" slotted/drilled rotors and Dynalite calipers are 56-1/2" hub to hub Thanks again, John |
08-07-2014, 08:04 PM | #7 |
Correction
The TCI suspension is 60" hub to hub for the 47-55 1st series Chevy trucks. The TCI suspemsion for 49-54 Chevy cars are 56-1/2" hub to hub |
08-07-2014, 10:30 PM | #8 | |
Marc
08-08-2014, 07:40 AM | #9 |
Yeah but it still sucks if the inner fenders are as nice as the paint job on the truck. That would drive me crazy. I'd pull the aftermarket one out and modify them so it wouldn't rub. So with your 20x8.5 having a 5" backset is the same as +6 mm offset. So if run a +20 mm offset which is 5.8" backset on my 20x9 wheels it will not stick out further but will be in about 1/2" or +14 mm more. If it rubs the inner fender itwill definitely be easier to fix than the outer fender. Man I hope this works
08-08-2014, 10:22 AM | #10 | |
Marc
08-09-2014, 02:21 PM | #11 | |
takes all the guesswork out http://www.summitracing.com/parts/php-01201 Last edited by Ricos54; 08-09-2014 at 02:25 PM. Reason: Adding a link in to help out a member make the right choice |
