Old 08-10-2013, 08:11 PM   #1
67_C-30
I have a radical idea!
67_C-30's Avatar
Found a new way to match the cluster texture on the glove box.
I love the '67 dashes more than any other year in these trucks because of the symmetrical look between gauge cluster and glove box door. The factory '67 had a textured surface with a silver outer that somewhat matched the gauge cluster grain. The factory glove box grain is not a real good match, though. I used 2 Rustoleum textured paints, and with a little experimentation, I pretty much nailed it.
Here's how I did it if anybody wants to do the same.
I painted the silver outside and then taped it up. I used the Aged Iron as base because it has the bigger textured pattern and it is gray in color.
The key is to hold the can about 2 feet away and dust it in light, even coats. DO NOT by any means spray it thick. Trust me - you'll have a huge mess QUICK!
After it pretty much dries (about an hour), do the same thing with textured black. Spray quick, even, light coats at about 2 feet away. If you spray it heavy, or get to close it "fills in" the grain like regular spray paint will do cluster if you put it on too thick.
It takes about 8 or so (I didn't count) light coats to get a good, deep, rich look. The black textured paint by itself actually matches the factory '67 glovebox grain perfectly, but I was wanting to match the cluster.
The light coats also help to keep the paint from trying to bleed under the masking tape. The tape line was good and crisp because of this.
Here's some pics.
This is an up close pic of the glove box.
This is an close pic of factory grain of the cluster. It is nearly identical to my glove box door..
Here is a pic of the 2 paints I used.
Here is the door installed. I noticed after I took the pic that I got some dusty fingerprints on it. I didn't see it, but the camera did! I am going to install the gauge bezel tomorrow.
I did something similiar years ago with spray in bedliner on my red '69 C-10. It turned out decent, but it didn't match like this did.
http://67-72chevytrucks.com/vboard/s...d.php?t=299203
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 08-10-2013, 11:40 PM   #2
mixermike
mixermike's Avatar
Re: Found a new way to match the cluster texture on the glove box.
Nice job looks great
mixermike is offline   Reply With Quote
Old 08-10-2013, 11:49 PM   #3
PAWS 72
PAWS 72's Avatar
I got a couple if you want to experiment for me. Since your in Bama I'm needing a road trip.hahaha
PAWS 72 is offline   Reply With Quote
Old 08-11-2013, 12:02 AM   #4
67_C-30
67_C-30's Avatar
My truck came from Killen!
My trucks
Old 08-11-2013, 09:59 AM   #5
Chvy2NV
That's sweet!!
Chvy2NV is offline   Reply With Quote
Old 08-11-2013, 07:07 PM   #6
heyjoe
Great how-to! Thanks for sharing.
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater.
heyjoe is offline   Reply With Quote
Old 08-11-2013, 09:21 PM   #7
BobbyB.
BobbyB.'s Avatar
Looks great! What silver did you use? And what did you use to prep the bezel?
BobbyB. is offline   Reply With Quote
Old 08-11-2013, 09:32 PM   #8
67_C-30
67_C-30's Avatar
I sanded the plastic chrome off of the outer bezel with 400 grit sandpaper. Most of it was gone already anyway. I used VHT argent silver wheel paint. It was the best match to '67 glove box I had.
My trucks
Old 08-11-2013, 09:42 PM   #9
That's a great tip. Looks good. I did a glovebox door spraying Dupli-Color bed liner after painting the desired color for the outer rim. Looks good as well.
Old 08-11-2013, 10:03 PM   #10
BobbyB.
BobbyB.'s Avatar
Awesome thank you
67 shortbed small back window turboed lq9, porterbuilt front and rear, and accuair e-level
Old 08-11-2013, 10:43 PM   #11
67_C-30
67_C-30's Avatar
Yes Tim, I copied your idea back when I did the glove box door on my red '69 and it does a good, too. I used some of that textured paint creating some fauxtina on an old JC Higgins boardtrack tribute bicycle a few months ago, and decided to try it.
Originally Posted by BobbyB. View Post
Awesome thank you
No problem! I forgot add that I wiped the whole thing down with acetone to try to remove any oil or old Armor All, etc.
My trucks
Old 08-11-2013, 11:21 PM   #12
67_C-30
67_C-30's Avatar
I got the dash cluster installed today, and it looks really nice. I'm just waiting on the new glove box emblem to come in now!
My trucks
Old 08-12-2013, 08:02 AM   #13
Looks fantastic. I'm sure pictures don't show much difference between the two methods. I thought you had tried that bedliner,too,so I'm thinking this looks even closer.
Old 08-12-2013, 10:53 AM   #14
8door
Not too old to learn
You just solved my dilemma on my 68 same light blue body.
I was ready to paint the glove box door blue, but this is so much better
Thanks for the post.......
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 08-12-2013, 08:54 PM   #15
67_C-30
67_C-30's Avatar
Thanks! The pic below was what I was going for, and I think I successfully '67'd it!
My trucks
Old 01-01-2014, 01:45 AM   #16
wesmigletz
wesmigletz's Avatar
Thank you for sharing. I'll be doing my glove box and cluster this spring.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 01-01-2014, 12:46 PM   #17
67_C-30
67_C-30's Avatar
Thanks! I've had a lot of compliments on it the cluster and glove box door. Everybody always thinks they are new. -lol
My trucks
Old 01-01-2014, 01:34 PM   #18
Sicklajoie
The Niner
Sicklajoie's Avatar
That came out great!
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 01-01-2014, 01:42 PM   #19
oklalawnboy
oklalawnboy's Avatar
Looks great! Maybe I can see it in person at a local car show.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 01-01-2014, 08:11 PM   #20
jorgensensc
jorgensensc's Avatar
Subscribed!
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 01-02-2014, 11:23 AM   #21
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Very neat process you shared. That might actually look good in my truck!
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 01-02-2014, 11:31 AM   #22
slowcpe
slowcpe's Avatar
I'll be using this method in the next week or two on my '67 glove box I managed to butcher up while stripping paint.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 11-05-2014, 08:52 PM   #23
goldenburb
goldenburb's Avatar
Thanks So much for posting.
I'm doing this method as I'm typing..
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
