Old 01-24-2018, 02:00 PM   #1
biohazardbill
Front Member questions
I know control arms for the c-10, c-20 and c-30 are different but are the actual front engine cradles, cross members, whatever you call it the same between the versions.
For instance can I put a half ton member into a 1 ton truck?
biohazardbill is offline   Reply With Quote
Old 01-24-2018, 07:13 PM   #2
SCOTI
SCOTI's Avatar
Re: Front Member questions
Yes, they are interchangeable. The difference between the 1/2 ton vs the others is the have smaller diameter upper a-arm studs & lack of reinforcement brackets in the frame channel.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
