Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-07-2018, 01:21 PM   #1
Rannos
Rannos's Avatar
Anti roll
I'm looking for opinions on which anti roll bar works better on a trailing arm truck. I have a 64 c10 thats been lowered 2.5 in the front and 5 in the rear. It use to 60ft in the 1.39 range but as I've turned the power up I have steadily lost 60ft times. The teuck is twisting up terribly and I want to add an anti roll bar to it. Right now it's welded stock trailing arms with good bushings and Viking crusader shocks. Any input is welcomed.
Rannos is offline   Reply With Quote
Old 03-08-2018, 02:26 PM   #2
PGSigns
PGSigns's Avatar
Re: Anti roll
How much of it is frame twist? I would go after that first.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-08-2018, 02:28 PM   #3
PGSigns
PGSigns's Avatar
Re: Anti roll
Also what springs are in it?
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-08-2018, 03:01 PM   #4
Rannos
Rannos's Avatar
Re: Anti roll
Jimmy
A good bit I'm sure but seeing as it separates and pulls the left rwad tire off the ground and mashes the right rear down so hard it almost shoves the wheel into the track I want.to keep the rear level more at this point. The truck needs chassis work. Trying to do what I can as I can.
I don't know the spring rate.of.the current.springs. They are 5" lowering springs amf.rather stiff. I've tried softer springs and it hit the tire harder and then rebounded to hard for the shocks to manage it.
Old 03-09-2018, 08:26 AM   #5
PGSigns
PGSigns's Avatar
Re: Anti roll
From what I have run over the years I always trouble tuning a flexible flyer. Here is what I would try if I was helping some one at the track. First step would be to ad a pound of tire pressure and tighten the compression on the right two clicks and tighten rebound on the left two. Then see what happens. Get some one to video the leave and see how bad the tire is wrapping up. That will tell you alot about your tire pressure and sidewall choices. A couple extra pounds and some help from the shocks to control the speed things happen can make a big change. Now what have you got in the front? How do you leave the line? Trans brake and two step of foot brake? Also hit can be worked with converter choice.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-09-2018, 08:58 AM   #6
Rannos
Rannos's Avatar
Re: Anti roll
I appreciate your input. I'll give that a try next time I'm at the track. I know the truck needs a good bit of chassis work. I building an s10 right now to swap this setup into. It's getting a 10 point cage atm. Once that's done and I'm racing it, the truck will get the chassis attention it needs and a little stouter drive train.
Old 03-10-2018, 01:00 PM   #7
Rannos
Rannos's Avatar
Re: Anti roll
And to answer your question. I leave off trans brake with a 2step. I've played with setting the 2step closer to my converter Ann's backing it down to let the converter flash more.problem persist either way. I just finished installing a 2 stage crossbar plate to try and leave a little softer and pull the second kit in a tenth or 2 out. Haven't got it back to the track yet.
Old 03-11-2018, 12:01 AM   #8
Super73
Super73's Avatar
Re: Anti roll
Does the truck drive out straight?
I know on my factory rear antiroll it was pulling the front left and causing it to drive right out of the hole. I made an antibiotic roll bar out of 1 3/4 tubing and RV bushings keeping it in the factory location. Problem solved.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 03-11-2018, 03:21 AM   #9
Rannos
Rannos's Avatar
Re: Anti roll
It drives straight unless spinning then drives towards the left.
