12-29-2018, 01:40 AM | #1 |
Airbag/ panhard bar question
I apologize if this is a dumb question but here goes:
I have a 70 c20, converting to rear trailing arms and adding airbags. Question is when lowering or raising the bags does it put pressure on the panhard bar enough to push the rear end side to side? Thanks |
12-29-2018, 01:57 AM | #2 |
Re: Airbag/ panhard bar question
Yes, the panhard bar is fixed to the frame at one end and moves in an arc as the rear end travels up and down. This results in the rear end also moving side to side. If you make the arc longer (as is often done with aftermarket bars) the result is less side to side movement.
12-29-2018, 02:44 AM | #3 |
That’s is what I thought. I am going to use a longer one from cpp. So do I get my ride height and set the panhard bar? Will low cruising cause any issues with the rear end being slightly kicked out from going up and down?
12-29-2018, 02:09 PM | #4 |
The amount of side to side will be acceptable if the panhard bar is level at ride height.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
