04-27-2020, 10:35 PM | #1 |
Stock Air Horn Compressor size
I have the factory (I believe ) air horns on my C50. Two horns on the roof. The air hose comes down through the roof and ends behind the rear seat area. There is no compressor.
I would like to get one to try and get the originals working but not sure what size to get. I don't want to blow them out. Does anyone have these on their truck and can you give me an idea what size compressor to get and where is yours mounted? Thanks |
04-28-2020, 06:25 AM | #2 |
Re: Stock Air Horn Compressor size
I have a engine mounted compressor on my truck. I also have another one sitting in the garage I pulled off my current engine. I believe it runs around 110-130 psi or so. If I was you I would hook up an air compressor to them and make sure they work before you do anything.
04-28-2020, 07:04 AM | #3 |
Have any pictures of how the engine mounted compressor bolts up to the engine?
04-28-2020, 08:29 AM | #4 |
Take a look at my build thread in my signature. There's a few pictures on page one and 2 of the motor. Nothing compressor specific but it shows it.
04-28-2020, 02:50 PM | #5 |
A factory Air Compressor would be nice, but if you just need one for your Air Horns, I would just go with an Electric aftermarket one. Although the nice ones can be a little pricey. I got an original set like the ones on your truck at a swap meet a few years back and tested it with my little 1 Gallon Compressor at about 100 psi. They sounded perfect at 100 lbs.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
04-28-2020, 04:49 PM | #6 |
Thanks, Pvmt-Pndr.
Det57, if you cant find a compressor, you may look into a york 210 compressor. They are pretty popular with the offroad world and they are able to use them for cheap onboard air. I dont know how the york 210 compares to the stock compressor. Based on Pvmt-Pndr's pictures, the stock compressor looks much bigger. |
04-28-2020, 06:18 PM | #7 |
the biggest york 210 model can do 10cfm of air .
for your air horn needs i would do a 3-5 gal tank and electric unit for fast / easy install and be done with it . viair is the top shelf of electric for them now last i checked .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
04-28-2020, 07:48 PM | #8 |
Since its only going to be used for your air horn I wouldn't get the biggest cfm you can find at all. I ran a small electric pump on a 3x horn setup for years with a 2 gallon air tank. I had a 140 pressure sensor in it. So what if it takes 2 minutes to fill the tank, you're not going to be blasting the horn constantly. I used the same small compressor when I made an 8 gallon tank that I could use to fill tires with.
04-29-2020, 04:12 PM | #9 |
From what I read, the york 210 is rated at 4 cfm @ 90 psi. Using an online tank fill up calculator, with a 3 gallon tank filling up to 140 psi, it would only take 57 seconds.
I do think an electric pump would be an easier install |
04-29-2020, 04:48 PM | #10 |
make sure you read up on the york . there is a few sizes and the 210 has the most cfm . i admit its been years for me so i might have forgotten some facts .
04-30-2020, 08:50 AM | #11 |
The York looks nice, but seems to be a good amount of work as well as a little pricey if you just need it for a set of horns. For the purpose of Air Pressure for Tires, etc, I could see it.
As bad as it sounds, lol, I like the idea of the Viair Ultra Light Duty, if you just need it for horns only. Once I get my 1-Ton on the road, I'll be looking into buying one. https://www.viaircorp.com/oba/oba-ultra-light I haven't checked into any reviews yet, but are there any negatives on it?
04-30-2020, 09:33 AM | #12 |
Seems like reviews are pretty good on summit.
https://www.summitracing.com/parts/var-10000/reviews at $130, thats not bad at all. |
04-30-2020, 10:05 AM | #13 |
It does seem like a good compressor kit for the money.
Thanks for checking on it.
