11-08-2020, 01:37 PM | #1 |
15x8 DON'T FIT?
Just got some 15x8 rally wheels and they don't clear the caliper on my 72...?
Sorry, pic won't load...is it a van wheel maybe?... |
11-08-2020, 02:05 PM | #2 |
Re: 15x8 DON'T FIT?
not oem brakes?
11-08-2020, 03:55 PM | #3 |
Re: 15x8 DON'T FIT?
I believe they are oem...
11-08-2020, 04:28 PM | #4 |
Moderator
Re: 15x8 DON'T FIT?
Looks like a 7” or maybe 6.5” wheel. No matter, should still clear calipers. 5 lug vans also had disc brakes. I’m guessing you have dropped spindles?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
11-08-2020, 05:23 PM | #5 |
Re: 15x8 DON'T FIT?
They are 8"...that's why i stumped. Its all stock...no drop spindles, no aftermarket brakes.
11-08-2020, 05:51 PM | #6 |
Re: 15x8 DON'T FIT?
My 15x8 fit my 70 but I have CPP brake kit from summit with 2.5 drop spindle. Those don't look deep enough to be 8 inch. I guess the picture can be deceiving.
11-08-2020, 05:56 PM | #7 | |
Re: 15x8 DON'T FIT?
Maybe 8 inches from wheel lip to wheel lip. Subtract 1 inch from that gives 7 inches. Rims are measured tire bead to tire bead. |
11-08-2020, 06:45 PM | #8 |
Re: 15x8 DON'T FIT?
11-08-2020, 06:53 PM | #9 |
Re: 15x8 DON'T FIT?
11-08-2020, 07:25 PM | #10 |
Re: 15x8 DON'T FIT?
Picture of caliper/spindle assy might help...
11-08-2020, 09:29 PM | #11 |
Re: 15x8 DON'T FIT?
I'll get SOME PICS of caliper TOMORROW. PROBABLY GOING TO BE selling THESE SINCE THEY DONT fit. Decent TIRES ON too... 235/75...
11-08-2020, 10:35 PM | #12 |
70+ ( Old Skool Club )
Re: 15x8 DON'T FIT?
Maybe at sometime someone when doing a brake job put different/bigger callers on the truckand were okay with the stock rims.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
11-08-2020, 11:44 PM | #13 |
Re: 15x8 DON'T FIT?
Could those be of something like an astro van with a little too much backspacing ?
Early wheels have this fitment issue as well usually with a wider inner bulge that digs into the caliper from a drum drum truck |
11-09-2020, 11:38 AM | #14 |
Re: 15x8 DON'T FIT?
I have factory 8" rally's and was planning on drop spindles because i am currently running factory cut springs. The A arm angle is pretty bad and not sure if the alignment shop can get the front end lined up. I don't want to go with a different wheel set up. So with 15" wheels, I cant run drop spindles? Thanks in advance, Carl
11-09-2020, 11:43 AM | #15 |
Moderator
Re: 15x8 DON'T FIT?
You can run dropped spindles, just have to do a little trimming on the lower control arm. Member lowlife99 has a good write up and pictures illustrating how/where to do this. Alignment is not an issue, I’ve run them on several trucks.
11-09-2020, 11:55 AM | #16 | |
Re: 15x8 DON'T FIT?
Thanks, I'll see if i can find his write up, Carl |
11-09-2020, 02:51 PM | #17 | |
Re: 15x8 DON'T FIT?
11-09-2020, 03:36 PM | #18 |
Re: 15x8 DON'T FIT?
Do you know the back spacing on them ,Dont look like they are as deep as mine 4 1/2" I belive is the BS. Ill have to go check later Soo looks like mine are 4" maybe 4 1/4" hard to tell with tire on
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 Last edited by kaycee; 11-09-2020 at 03:53 PM. Reason: Brain tumor |
11-09-2020, 07:43 PM | #19 |
Re: 15x8 DON'T FIT?
Here is likely a dumb question. Is the lug pattern 5 x 5 or 5 x 4.75? Not sure it matters . . .
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
11-09-2020, 08:20 PM | #20 |
Re: 15x8 DON'T FIT?
So the backspacing is the reason they are hitting the calipers?
11-09-2020, 10:05 PM | #21 | |
Re: 15x8 DON'T FIT?
11-10-2020, 06:40 AM | #22 |
Re: 15x8 DON'T FIT?
This totally baffles me because truck rallyes only came on trucks with disc brakes.
11-10-2020, 10:07 AM | #23 |
Proprietor of Dale's Corner
Re: 15x8 DON'T FIT?
X2, strange.......
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
11-10-2020, 10:55 AM | #24 |
Re: 15x8 DON'T FIT?
i have a 1999 OBS Tahoe 4 x 2 with the Police Package. Now I've seen lots of OBS trucks with the 80's rallys on them and they fit and work great. I tried to put a set on my Tahoe and they wouldnt clear the caliper. I didn't measure the calipers but sure they are bigger than on a stock non-police OBS truck or Tahoe. Thats why I mentioned earlier in this post that maybe the calipers were changed at some time and bigger ones and maybe not from a 71-72 C10 were used.
11-10-2020, 01:55 PM | #25 |
Re: 15x8 DON'T FIT?
https://www.cokertire.com/wheels/pic...lye-wheel.html
Here is a similar rim Coker Tire sells. Looks the same from the front. Description states it fits 71 to 87. Maybe a picture of the back side of your rim will yield some clues? Also a picture of the brake caliper?
