05-01-2021, 09:37 PM | #1 |
Engine for my c10
So instead of rebuilding the C10's 350, I was looking at putting together this engine
Vortec cast intake - https://www.ebay.com/itm/17471686261...kAAOSwA3dYP0E2 Summit Vortec heads- https://www.summitracing.com/parts/sum-151124 ZZ350 short block- https://www.summitracing.com/parts/nal-19419042 10105117 head gasket .015 compressed- https://www.ebay.com/itm/30354225752...53.m1438.l2649 08-411-8 Comp Cam- (extreme 4x4 210/218@.50, .474 lift https://www.summitracing.com/parts/cca-08-411-8 1978 Big 10, currently 350, Th350, 3.08 235/75r15 Looking for more midrange power, might even go to 3.23 gears. Mix of highway and street driven. |
05-04-2021, 05:56 PM | #2 |
Re: Engine for my c10
I have a simaler build roller cam block comp extreme 4x4 cam vortec heads edlbrock preformed intake
Had the valve seal tower cut down by machine shop same size seal as stock Comp cams makes a tool to do this as well It will run well If I went marine intake I would go for the fuel injected one and run it on a 411 ecm |
05-05-2021, 12:24 PM | #3 |
Thank You
05-05-2021, 01:37 PM | #4 |
driving is in my blood
I would not use a marine carb intake, I'd get a performer RPM.
I would use oem vortec heads instead of aftermarket. Cam and shortblock look good. Build wise great combo.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
