Old 05-31-2016, 11:59 PM   #1
saxart
saxart's Avatar
Brake Parts
I'm having a devil of a time finding a vendor who carries these for our 1/2 ton trucks. LMC carries them, but they appear to be for a 3/4 truck. Anybody have a source for them for our 1/2 ton trucks?
Thanks!
(Numbers 8 & 9 in the diagram)
saxart is offline   Reply With Quote
Old 06-01-2016, 09:42 AM   #2
cdowns
cdowns's Avatar
Re: Brake Parts
readily available here at local autopartsd store in the help section
Old 06-01-2016, 11:36 AM   #3
dfwright
dfwright's Avatar
Re: Brake Parts
The oval spring is available from NAPA - #80744
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 06-01-2016, 02:05 PM   #4
saxart
saxart's Avatar
Re: Brake Parts
Originally Posted by cdowns View Post
readily available here at local autoparts store in the help section
That's good news. You wouldn't happen to have a part number or a brand name, would you? I looked on the interweb last night, and found a bunch of Dorman units, but of all the different part numbers none seemed to fit a 1/2 ton 1970 C-10. (or any 1/2 ton C-10 for that matter)
Thanks Dfwright, that's a great start!!
Old 06-02-2016, 12:18 AM   #5
TexasLS1
TexasLS1's Avatar
Re: Brake Parts
I had to do my own research for the bar and spring bc no auto parts stores had them listed for our year model trucks - trying to have them search for me was a waste of time. I found these drum bar at O'Reilly, Dorman part # 21152 -- http://m.oreillyauto.com/h5/r/oap/si...&keyword=21152
Here are the springs as well, BrakeBest part # H1338-2 -- http://m.oreillyauto.com/h5/r/oap/si...eyword=H1338-2
They had to special order them and I picked them up a few days later
TexasLS1 is offline   Reply With Quote
Old 06-02-2016, 06:36 AM   #6
saxart
saxart's Avatar
Re: Brake Parts
Tex-
Thanks for the info. I don't know HOW you figured out that these fit our trucks, as they don't even list our vehicles, but I'll certainly give them a try. Thanks so much for posting this info!
Old 06-04-2016, 07:49 PM   #7
saxart
saxart's Avatar
Re: Brake Parts
I want to thank everyone here for their help with this. The brake struts and springs that "TexasLS1" mentioned seem to be a great fit.
Now for another question...
My cables showed up today from LMC. They look like decent quality, but I guess time will tell. Anyway, I noticed that they are VERY loose where they pop in through the back of the brake backing plate. Is there supposed to be some sort of a washer or bushing to take up the slack? The little "barbs" that pop out do hold the cable in the hole, but it's as if the hole was drilled way too big (or I possibly have the wrong cables?) as that end of the sheath can be wiggled around enough that you could probably pull it out if you wrestled with it enough.
Here are some pics with the cable popped through the backing plate. I'm guessing something here is wrong, if anyone has any insight, that would be great!
Inside the brake set up:
Back side of backing plate: (Here you can see the daylight between the cable and the hole in the backing plate)
Thanks again for all of the help. I was able to figure out which parking brake arms were needed by a quick forum search. This place is great!
Old 05-20-2021, 12:07 AM   #8
Asshat
Asshat's Avatar
Subscribing
Asshat is offline   Reply With Quote
Old 05-20-2021, 09:58 AM   #9
Grumpy old man
Grumpy old man's Avatar
Re: Brake Parts
Originally Posted by Asshat View Post
Subscribing
5 year old thread ,The links don't seem to work anymore . Another option is Rockauto they had everything when I replaced mine with AC DELCO parts and they fit great .
https://www.rockauto.com/en/catalog/chevrolet
