![]() Join Date: Apr 2001
Front inner fender well help needed
I have an '88 K5 with front quaf shocks. Like I've done before I ordered new parts, in this case, inner front fenders from Rock Auto. Put them on the shelf till needed without opening to check for damage. Left was fine. Right side is dented (I took them still as received straight to the powder coating shop without inspecting first.)
Like John Wayne said, "Life's hard. It's even harder when you're stupid." I've ordered enough parts from there to know to check them right away. Well, turns out right side also doesn't fit with the quad shocks! Any chance somebody could take a picture of that side near the shock so I can figure out how to cut it so it will resemble what the original looked like? Of course I pitched those a long time ago. I'd be greatly appreciative. Thanks for any help you guys can give me.
1967 K30 461/TH400/Np205/D60/14FF/BDS MTZ 375/75/16 on 16x10 Pro Comps |
Just here to tinker
![]() Join Date: Jun 2008
Re: Front inner fender well help needed
Here you go. The rear ac lines are kind of in the way...but it looks like the factory only cut out the hole for the top shock. The lower shock is under the well.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
Corts60, Thanks for the pictures. I now know how to cut it. Your awesome!
