10-01-2021, 08:13 AM | #1 |
4x4 front axial
Bought a 1971 blazer frame don't look like the right axial.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
10-01-2021, 10:10 AM | #2 |
Proprietor of Dale's Corner
Re: 4x4 front axial
What looks wrong to you?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
10-01-2021, 10:12 AM | #3 |
Carpe manana
Re: 4x4 front axial
An OEM 71 front axle wouldn't have a bracket for the steering damper. The backing plates look different to me too.
10-01-2021, 11:02 AM | #4 |
Re: 4x4 front axial
Don't look any thing like me 72 jimmy.
10-01-2021, 12:02 PM | #5 |
Re: 4x4 front axial
Looks like a late 70's Dana 44 or GM corporate 10 bolt based on the upside down tierod ends, no flat top passenger side knuckle and placement of the steering damper. Also the brake dust shields are heavy gauge steel instead of the sheetmetal used on the early Dana 44's. Post a picture of the differential cover please.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
10-01-2021, 04:12 PM | #6 |
Re: 4x4 front axial
Pics
10-04-2021, 09:20 AM | #7 |
Re: 4x4 front axial
Its a Dana 44, there is a number stamped on the front of the long axle tube that will tell you the build date- or you can pull the diff cover and get the date from the ring gear as well, along with the ratio.
10-04-2021, 04:41 PM | #8 |
Re: 4x4 front axial
Found a tag looks like 373 don't no what 41-11 means.
10-04-2021, 04:50 PM | #9 |
Re: 4x4 front axial
41 ring gear teeth
11 pinion teeth 41/11= 3.727 or 3.73 ratio
10-05-2021, 08:13 PM | #10 |
Re: 4x4 front axial
Found the date 1-12-76 looks like the caliper my be the same as my 72.
