![]() Join Date: Aug 2016
Parking brake cables
Ok so I'm trying to figure out the parking brakes for my truck, I found the cable that connects to the pedal, but the rear brakes are 13" brakes from a late 90s GMC k2500 full floating 14 bolt rear so idk if the 71 parking brake cables will work or if I need the parking brake cables from the later model truck, from there my next question would be do I need the intermediate cable that matched the rear cables or can I use the one for the 71? If anyone can help it'd be much appreciated cause that's all I need other than a proportioning valve to finish the brake system on my 3/4 ton frame so I can move the body over.
Re: Parking brake cables
Anyone?
![]() Join Date: Dec 2013
Try both cables that you already have and see if one of them will work , There's nothing off the shelf that's made to solve your problem , You may need to fabricate one yourself . The joys of building a franken truck . The intermediate cable would probably be the easiest part to join the old and newer system together .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
I put a Ford 8.8 in my truck and used the original front cable. Dorman makes a universal cable that worked great to connect the 2 rear axle cables to the front cable, similar to how the factory had it. The universal cable was $10 and had a clamp to stop the cable from slipping. You cut, put on the ball, then add the clamp. The cable was a fair amount smaller than the original, but it works great.
Thanks, I'll look into the dorman cable and I'll try the 71 cables I have to see if they'll work on the 13" drums
you have a mismatched parts no one can answer.
Instead use the cables you have to determine their current length . and questimate your desired new length. Then you know, you need a cable approximately xxx Inches long. |
![]() Join Date: May 2003
I changed my rear drum brakes to disc. I used stock front and intermediate cables, and had custom made to fit my components rear cables. There are several companies that make custom cables.
Good luck ! Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
