Old 05-22-2020, 10:05 AM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Center drive shaft bearing or one piece drive shaft??
Has anybody done a one piece drive shaft??
desert-rat is online now   Reply With Quote
Old 05-22-2020, 09:51 PM   #2
lutronjim
Re: Center drive shaft bearing or one piece drive shaft??
Replaced the one in my 70C10 and loved it. I lost count of how many rubber 'bushings' I had to replace for the 3 piece.
lutronjim is offline   Reply With Quote
Old 05-22-2020, 11:18 PM   #3
fb111ewo
fb111ewo's Avatar
When I bought my truck, PO had a one piece drive shaft in it. After I installed a new motor/transmission with the correct motor mounts, the existing driveshaft didn't seem to fit (too short). I ended up having another one piece made by a driveshaft shop. The guy was pretty knowledgeable and said that the driveshaft that I had (brought it in with me) was too small in diameter, and would have definitely caused vibration when driving at higher speeds. The new one is much bigger in diameter and I won't know of issues until I finally get it back on the road.
I think you will find people in this forum that will argue both ways concerning the merits of a one piece vs 2 piece drive shaft.
fb111ewo is offline   Reply With Quote
Old 05-23-2020, 06:33 AM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Center drive shaft bearing or one piece drive shaft??
I had 2 piece for many years and had no major problems. I had the 6.0 installed and they cut the 2 piece to short. So they had a 1 piece installed at no cost to me. I have no problem with it and I have a LWB truck.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-23-2020, 02:05 PM   #5
MidLifer
MidLifer's Avatar
Did a one-piece with my LQ4/4L80e in my LWB. No vibration or noise. Happy with it. I say go for it.
MidLifer is offline   Reply With Quote
Old 05-23-2020, 04:30 PM   #6
LS short box
A good drive shaft shop will ask your max engine rpm and length then determine shaft diameter. Mine is 3.5" diameter.
Old 02-07-2022, 09:51 PM   #7
Peanut74
I went to get my drive shaft shortened and made into a one piece. Long story short I'm getting a 3.5" one piece drive shaft made. My question is was does the cross member need to be modified or will it fit in?
1967 C10 "Snowball" (Currently in a million pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
2012 Jeep JKU "Crush"
1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer)
1971 Chevy Blazer (Sold it)
Peanut74 is offline   Reply With Quote
Old 02-07-2022, 10:12 PM   #8
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
hmm, what the benefit of actually going one piece drive shaft (I get you get rid of that carrier bearing)? There has to be a good reason to have a two piece with a LWB, right?
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 02-08-2022, 12:04 AM   #9
Jason Banks
Jason Banks's Avatar
The 3.5" will fit in the hole. Whether or not it hits top or bottom depends on modifications your truck might have.
I have 4/6 lowering with LS 4L80E swap and was hitting the top of the crossmember...
Jason Banks is offline   Reply With Quote
Old 02-08-2022, 09:26 AM   #10
Keith Seymore
Keith Seymore's Avatar
The concept is to control the driveshaft "critical speed", the point at which it begins to swing like a jump rope. It is affected by length, outside diameter, thickness, material type, mass and rpm. Highest shaft rpm is affected by vehicle top speed, rear axle ratio and tire diameter. Length is affected by wheelbase and driveline configuration.
The driveline is also affected by any unusual or unpredicted system resonances, which can destroy a driveline even at a speed lower than the critical rpm.
From an OE perspective the driveshaft choice (one piece vs two piece) can be manipulated by controlling any one or more of those variables. The trade off is the added cost of the two piece system vs selling a vehicle with a top speed which is lower than desired.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-08-2022, 02:35 PM   #11
BigBird05
Keith I love your opinions. Did you make the move to Pontiac? I was there from 97 till I retired in 2002. I worked in the engineering bldg.
BigBird05 is offline   Reply With Quote
Old 02-09-2022, 04:07 PM   #12
Keith Seymore
Thank you - I did.
When I came back from the Desert I was at the Tech Center in Warren ever so briefly, and then moved to the white castle on South Blvd.
We were in Pontiac for several years, before they shut down the Truck Validation Center and all of CenterPoint completely and shipped us back to Warren.
K
1979-1986
1986 - 2019
Old 02-09-2022, 06:16 PM   #13
AllGoNoShow
A 4" shaft will also fit in the driveshaft hole for the trailing arm crossmember, if your interested. But, if you go low, you may need to raise the top of the hole to prevent driveshaft interference at max suspension travel (I put up some pictures of what I did on a different thread).
I replaced my one-piece 3.5 driveshaft on my long-bed with a 4" driveshaft when I did a tranny swap-if you look into "critical speeds" of driveshafts, when they get as long as they need to be for a long-bed, you start reaching this critical speed (rpm at which point the driveshaft becomes unstable and starts whipping like a jump rope) of a 3.5" driveshaft around 85MPH depending on specifics of gearing, etc. Jumping up to a 4" driveshaft gives you substantially more RPMs/speed before reaching this point.
AllGoNoShow is offline   Reply With Quote
Old 02-09-2022, 08:10 PM   #14
Peanut74
Thanks for the input guys. I have been getting an education on this matter. I have removed the center bearing carrier bracket since I won't be using it. From what I understand I should be ok since I'm not doing a big drop.
I should have stated that I changed the truck from LWB to SWB and its currently at standard ride height. If I do drop it I will probably do a 2/4 to close up the wheel opening gap.
Old 02-10-2022, 07:54 AM   #15
BigBird05
Originally Posted by Keith Seymore View Post
Thank you - I did.
K
Ya thats the place. I couldn't remember the name after all of these years. I started at Olds, then transferred to the Truck validation center in 97 till I retired in 02.
Old 07-06-2022, 12:46 PM   #16
smokeatr23
I know this is an old post, but do you know the drive shaft diameter and have you had any trouble with it hitting the crossmember? Is yours swingarm rear?
smokeatr23 is offline   Reply With Quote
Old 07-06-2022, 12:48 PM   #17
smokeatr23
