05-18-2024, 09:05 AM | #1 |
L6 with headers heat to carb
Looking for some information on installing heat to the carb on my truck using an Offenhauser intake and cast iron headers. I have purchased a plate from Offenhauser to bolt to the bottom of intake below the carb, it came with brass fittings to a water hose on. I'm sure a few of you folks have used this method, was looking for pro's and con's of doing this, also hopefully pictures of how you routed the hoses and how you tapped into the heater hoses. Has anyone had a problem with leakage, I was planning on making a gasket, I doubt if you can buy one. Appreciate any help you can offer.
05-18-2024, 09:47 AM | #2 |
At the body shop.
Re: L6 with headers heat to carb
My brother's 56 with a 235 isn't plumbed and hasn't has any issues.
However in central ca weather probably 40° as cold as it gets driven in.
" That didnt make it any newer " " Dont antique the equipment " |
05-18-2024, 10:49 AM | #3 |
What type of header do you have?
Here is a setup on a Fenton header for heat from the exhaust.
05-19-2024, 08:10 AM | #4 | |
05-20-2024, 04:28 PM | #5 |
IMHO, unless you drive the truck in freezing, or colder, climate....the last thing you want is heat to carb
05-20-2024, 05:09 PM | #6 | |
It's about the same as driving a V8 with an air gap manifold or the heat cross over passages blocked off and headers rather than manifolds with a heat riser. It is going to be a bit cranky driving until you get it warmed up to operating temp most of the time and more so when it gets colder. In some cases in some conditions the carb can ice up. For most it is a case of "well, I have to let it warm up a bit before I drive off down the street so it will run right".
05-20-2024, 10:35 PM | #7 | |
05-21-2024, 12:11 PM | #8 |
Thanks guys, I have the carb off right now so that that would be a good time to install the heat plate, my big hands don't want to fit in those small tight places. I thinking this should have been done before the intake was installed. Not wanting to tear it all apart I believe I'm going to put the hole thing on hold for the time being and drive it a while and then go from there. Appreciate all the input.
05-22-2024, 02:01 AM | #9 | |
Once, 30 or 40 years ago, when I ran the Holley 390 CFM with a sort-of Rube Goldberg bellcrank linkage -- I experienced real carb icing. It was Winter, and I was coming down from a ski trip in the White Mountains. I ran into a sleet storm before hitting Globe and my linkage froze up. I was stuck in high RPMs. I managed to make it to my halfway hamburger stop by feathering the clutch. I stalled the clutch to stop the engine. After coffee and a couple of cheeseburgers, the higher temps at the lower altitude let the linkage thaw out, and the second half of the trip was nominal. I realized why Cessna 150s had a Carb Heat knob. One reason why I converted to a cable/throttle linkage on the next rebuild.
