12-14-2020, 10:40 PM | #1 |
Clutch/SM465 trans parts
I have a few Z bars, clutch linkage rods and SM465 parts. Also parting out the sm465 trans. If you need anything else let me know I may have it. Prices are plus shipping. 1 of the Z bars has a weld repair on it. I believe I have a frame bracket I will look for and post pictures.
I AM OPEN TO OFFERS lol Repaired z bar $10 Z bars $20 each Spring $10 SOLD Clutch adjuster rods (pedal to z bar & z bar to pivot fork) $10 each U joint caps (greasy) $15 SOLD Pivot fork w/ pivot ball clip $20 Dust shields pair, crack on top of starter hole $20 SOLD Gear shifter with associated parts to fasten to top of trans came off 69 c10 6cyl 2wd $40 PTO cover with bolts $20 Bellhousing mounting bolts w/ locking tabs $10 Pivot balls on engine side $15 V8 SOLD 3 speed column shift linkage came from 65 c10 6cyl $10 Posted via Mobile Device Last edited by chev-obsession; 12-27-2020 at 07:42 PM. |
12-15-2020, 07:54 AM | #2 |
One of the First
Re: Clutch/SM465 trans parts
What's the issues with the transmission as a whole? Pop-out of gear in 3rd? Common problem with these?
Interested in Top plate assembly (minus shifter) and speedo gear on side.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
12-15-2020, 10:54 AM | #3 | |
How about $50 on the plate and $10 for the speedo gear plus shipping?
1965 c/10 swb 1969 c/10 lwb |
12-15-2020, 11:04 AM | #4 |
PM sent on flywheel covers.
Thanks, Joel |
12-15-2020, 02:33 PM | #5 |
In line for the speedo gear.
You ever have one of those mornings where you wake up owning more trucks than you did the night before? 1972 K5 1972 K10 1967 K20 bucket truck |
12-15-2020, 05:34 PM | #6 | |
One of the First
Funds sent
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) Last edited by D.PASSMORE; 12-18-2020 at 10:19 AM. |
12-16-2020, 10:12 AM | #7 |
I will take the 2 adjustment rods
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
12-18-2020, 02:40 AM | #8 |
I made a sale locally on another adjustment rod I had and robbed the Clevis and nuts from the rod on the right. Are you still interested in both rods?
12-18-2020, 02:43 AM | #9 |
I have not forgot about your shipping quote on the covers. I will get a quote tomorrow
12-18-2020, 09:22 AM | #10 |
can you give me an aprox length on them please. and what did they come off of? 2wd or 4wd.
12-18-2020, 12:24 PM | #11 | |
I had one rod on my 6 cyl 2wd application, cant remember which one and im not sure of the others original application
12-18-2020, 12:30 PM | #12 |
Ok, thanks.
12-18-2020, 01:06 PM | #13 |
Hi, interested in the parts in picture #5. The 2 universal plates and 4 bolts
12-18-2020, 06:18 PM | #14 |
$20 shipped + PP fees
12-18-2020, 08:36 PM | #15 |
12-18-2020, 10:37 PM | #16 |
12-19-2020, 09:24 AM | #17 |
I think I will go ahead and pas on them,Thanks, sorry for your trouble
12-27-2020, 07:43 PM | #18 |
Ttt
01-14-2021, 12:09 AM | #19 |
Open to offers on this stuff, don’t be afraid to make an offer if you are interested in something
01-30-2021, 02:34 PM | #20 |
Ttt
01-31-2021, 01:15 PM | #21 |
Hi. I’m interested in the pedal to z bar rod in pictures 4. The straight one on the right. I think it’s for the I6 style. If the ends are not extremely worn. I also wanted to see if you had a set of the 5 little bolts that hold the starter shield and the flywheel cover on. Thanks.
01-31-2021, 07:23 PM | #22 |
Pictures for Awann99. The 6cyl rod is a little worn on one end. Measures about 19.75” center to center and 3/8” diameter rod. I would do $16 shipped to the Dover, TN zip code.
Also found a heavier rod, 19.75” center to center in length and 1/2” diameter rod, but worn on both ends.
02-04-2021, 03:40 PM | #23 | |
02-23-2021, 02:54 PM | #24 |
Ttt
Posted via Mobile Device |
04-24-2021, 01:50 PM | #25 |
I need a few more parts if you still have them. I need the longer z bar to pivot fork rod used on i6 trucks. The plug for the reverse lights on the transmission. On that sm465 it looks like there is a Speedo corrector on the speedometer hole. I would like to buy that as well. My Speedo is slow by 10 mph so it may work for me.
