09-30-2002, 02:55 PM | #1 |
Engine tower differences
Can anyone tell me the difference between 6 cyl and 8 cyl engine towers? Or is it just the location that differs? Also is the frame drilled for both the 6 and 8 positions?
I recently bought a 69 SWB with no engine or trans and plan to install a 350/350 combo. Any info is appreciated. Thanks. |
09-30-2002, 03:09 PM | #2 |
I Love This Stuff!
I was wondering that same thing about my 67, that i'm putting a 400sb in. It had a 250 in it.
thanks JHickson6
My Rides 1967 C10 In Pieces for now 1985 Ford B700 SourPuss Bus - BIG BLUE 2003 Silverado CITY WORKER YELLOW!! |
10-01-2002, 12:15 AM | #3 |
its all about the +6 inches
Does this help any?
Stock small block location. |
10-01-2002, 01:18 AM | #4 |
Fabricate till you "puke"
The 6 cyl & v8 stands are different stampings,& do also bolt down in different positions(all holes are in the frame). The v8 will bolt down on the 6/250 stands,but does leave the HEI dist pretty tight to the firewall,as the engine is set back aprox 3 1/2" from factory v8 location. My longhorn is set up this way for a little weight transfer on the lwb truck. Good luck......crazy AL
10-01-2002, 09:57 AM | #5 |
Thanks for the replies and info.
One more question. I understand the 8 cyl original location for the engine towers is the forward position, so I now know where to locate the towers in the frame. However, what is the difference in the towers themselves? When I got the truck all parts for it were in several boxes. The towers were included, but how can I tell if they are for a 6 cyl or 8cyl, and does it matter which are used so long as they are in the right location? Thanks again. |
10-01-2002, 10:28 AM | #6 |
If you look at longhorn's pic, his V8 towers mount to the front of the crossmember........the 6/250 towers mount to the rear of the crossmember. To answer the Q, yes they are different parts(6 to v8),but you can use either set. the 6 /292 towers are different (staggered), & cant be used to mount a v8. I would set the towers down on the frame, & see which set of holes line up.......6/250 stands in proper position should leave 1 bolt hole showing at the top of the frame rail ea side(ahead of the stand). Hope that helps.......Crazy AL
10-01-2002, 04:05 PM | #7 |
I Love This Stuff!
Longhornmail, please tell me you bought the frame like that, or i'm going to start crying
10-01-2002, 10:43 PM | #8 | |
There is a thread...probably a few pages back on this.... titled been two years as of sunday. |
