12-16-2008, 06:22 PM | #1 |
you want to change your 5X5 bolt pattern on 73-87 disc to 5X4.75
Now we all know that the 73-87 front crossmember and suspension components can be swapped into the 60-72 trucks. The 73-80 Chevrolet C10 pickups used a 1.28 rotor. Then in 81-86 GM switched to a 1" rotor. I did a bit more digging and found that the calipers are different for the 1" rotor but use a common bolt pattern with 73-80 so, it looks as if the 91 Camaro rotor will work on the 73-86 spindles if the 81-86 calipers are used as well. Also the flexible brake line will need to be changed if you have the 73-80 caliper as one of the calipers uses American standard thread and the other uses a metric thread. The parts house could not tell me which one used what thread but that they were different. I will figure that out when I purchase the parts. I have not done this yet but it does look like it will work. fones1966 a member here PMed me telling me about this possibility and I want to thank him for that. I just thought I would post this information in case there were others that could use it. Olympic Brake here in Washington is who provided this information. One note I want to point out is the specs that I have all show the same bearings on all three rotors. I was told by fones1966 that the 73-80 1.28 rotor used a A-5 inner bearing so that bearing would have to be replaced when switching to the Camaro rotor but, what I found was the 73-80 heavy duty 1.28 rotor used the A-5 inner bearing and the 81-87 light duty rotor used the A-6 as shown in the specs I have provided. I hope this information is helpful. Here are the specs on both the truck and Camaro rotors:
73-80 Truck rotor specs are: Height 4.88 Diameter 11.85 Min. Thickness 1.220 Hub 3.06 Outer bearing A-3 Inner bearing A-5 Seal Part # 8871 Bolt Circle 5X5 81-86 Truck rotor specs are: Height 4.63 Diameter 11.86 Min. Thickness .96 Hub 3.20 Outer bearing A-3 Inner bearing A-6 Seal Part # 8871 Bolt Circle 5X5 91 Camaro 1LE Performance Package rotor specs are: Height 4.65 Diameter 11.85 Min. Thickness .97 Hub 2.78 Outer bearing A-3 Inner bearing A-6 Seal Part # 8871 Bolt Circle 5X4.75
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 01-28-2009 at 02:18 PM. |
12-17-2008, 10:33 AM | #2 |
A guy with a truck
Re: Do you want to change you 5X5 bolt patern on 73-87 front disc to 5X4.75
The Camaro rotor will work on the '81-up 1" spindle. It will not work AFAIK on the 1.25" early spindle...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-18-2008, 09:45 PM | #3 |
Well after much research and comparisons this is what I have come up with. I would like to thank gringoloco he helped me out here. The 73-87 2-1/2 drop spindle from CPP uses the A-5 inner bearing that has a 1-3/8" bore. This spindle uses the 1-1/4 rotor with the 5X5 bolt circle. This is the same size spindle as the OEM as well. Belltech has a 3" drop spindle that uses the A-6 inner bearing that has a 1-1/4" bore. This spindle uses a 1" rotor and there for can either be used with the light duty truck 1" 5X5 bolt circle rotor or the Camaro 1" 5X4.75 bolt circle rotor. There it is. This is the only way that I found to switch from the 5X5 bolt circle to the 5X4.75 bolt circle using the OEM rotors. Hope this helps
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 12-18-2008 at 09:46 PM. |
12-18-2008, 11:31 PM | #4 |
Keepin it old school
good to know
12-18-2008, 11:42 PM | #5 |
why would you want smaller brakes and smaller bolt pattern?
just curious.....
CHEVY ONLY |
12-19-2008, 09:21 AM | #6 |
Happy to be here
There is no advantage with the smaller bolt circle, there is an advantage with the Camaro brakes. Even though they are a 1" thick rotor, they can be had in a much larger diameter as well as bigger calipers.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 04-02-2009 at 11:08 AM. |
12-19-2008, 03:06 PM | #7 |
If you notice in the first post the Camaro rotor is almost identical as both the 1" & 1.25 truck rotors. The advantage is the 5X4.75 bolt circle in my case. I have a new set of 18X8X4.5 with the 5X4.75 bolt circle Billet Specialties wheels that I want to use on the front of my truck and because you like pictures Joe....
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 12-19-2008 at 03:11 PM. |
12-19-2008, 09:37 AM | #8 |
Re: you want to change your 5X5 bolt pattern on 73-87 disc to 5X4.75
ahhh, I see
CHEVY ONLY |
12-21-2008, 12:51 AM | #9 |
good info,i ran into the same problem, bought some nice cheap 20s and adapters but they wouldnt tuck, so i took my rotors to a machine shop and they knocked the studs out and redrilled the rotors to 5x 4.75 and put my stock studs back in for $100 for the front, and if i ever wanted or needed to go back to 5x5 all i gotta do is knock the studs out and put them back in the factory holes, i took my axles and drums and had them done too for $100
12-21-2008, 08:46 AM | #10 | |
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 12-21-2008 at 08:47 AM. |
12-21-2008, 04:06 PM | #11 | |
The use of 1LE rotors on LT duty truck spindles would work for a limited use application. But one of the first upgrades made to F-bodies is bigger/better brakes (rotors) that don't warp as easily as the stockers would/could.
12-22-2008, 03:52 PM | #12 | |
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
12-22-2008, 04:35 PM | #13 | |
It also has a lot to do w/factory rotors vs. an aftermarket supplier as not all parts are created equal.
01-30-2014, 11:24 AM | #14 | |
'87 R10 - 5.3, 4.8 Flat Top Pistons, 220r Cam, Long Tubes, P&P 862 Heads, 4L80e '84 C10 - 5.3, LS6 Cam, 4L80E, 3.73, Ported Heads 329hp/334tq !! STOLEN !! 2-15-13 North AL Click Here:How To DIY Port & Polish LSx Heads Videso by "AGearHead4Life" |
12-22-2008, 04:41 PM | #15 |
A guy with a truck
Most F-body guys upgrade to the 1LE brakes. There are kits out there to upgrade to a '98-'02 F-body front brake(12x1.25 -basically the same as your truck brakes) or C5/6 brakes which are 13x1.25. There are upgrades from there to Z06 or Z51 brakes but the parts get spendy...
I've been researching this a little. It looks like the aftermarket C5 upgrade brackets might work on the light duty spindles. That is, if the dust shield/backing plates interchange between big car/light truck, then a bracket may already exist to adapt the 'Vette stuff. More to come when I get some time...
12-22-2008, 05:00 PM | #16 | |
12-23-2008, 10:24 AM | #17 | |
08-16-2012, 11:28 AM | #18 | |
A guy with a truck
08-16-2012, 11:06 PM | #19 |
A guy with a truck
Got some parts today-early measurements say it's gonna work More to come...
08-18-2012, 10:46 PM | #20 |
Gringoloco-
My backspacing on my 15" Centerlines is 1.5 inches at best. They are the 15x3 Convo Pros. So I shouldn't have any issues with the 91LE rotor and those drop spindles I linked right? Thanks again. Posted via Mobile Device |
08-27-2017, 05:56 PM | #21 | |
Can you provide a part number for them. I have a 66 chevelle and my current rotors make the front wheels sit to close to the fender lip, these low profile rotors look like they could solve my problem. will they work with the stock calipers? thanks |
08-28-2017, 12:21 AM | #22 | |
A guy with a truck
01-12-2009, 03:01 PM | #23 |
So ALL '73-'80 half ton 2wd trucks have the 1.25" rotor?
Thanks!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
01-12-2009, 04:23 PM | #24 |
A guy with a truck
Yes. '71-'80 actually. Around '81 was the start of the light duty brakes.
01-13-2009, 02:45 PM | #25 |
And you should be aware that not all '81 up 1/2 tons have the light duty brakes. My 87 1/2 ton has the bigger brakes because it's a diesel (and thus very nose heavy).
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
