Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 06-14-2009, 02:40 AM   #1
JWOLVES
JWOLVES's Avatar
96 s10 blazer 4.3 won't start
i have a friends blazer they tried to replaced the distributor and can't set the timing on it i need help and maybe a diagram on how to set and where the timing mark is on the distributor i set it in between the 2 and the 4 wire on the cap this is self timing do i have to unplug a wire or something to reset it it will not start and i'm about to replace the timing chain and gears can anyone help thanks
JWOLVES is offline   Reply With Quote
Old 06-14-2009, 07:11 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 96 s10 blazer 4.3 won't start
Use the same procedure as a V-8 to find top dead center.
http://www.73-87.com/7387garage/drivetrain/disremov.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 06-14-2009, 08:46 PM   #3
JWOLVES
JWOLVES's Avatar
the cap is not like a regular cap it has the plug wires on the side of the cap not the top 3 on the drivers side and 4 on the passenger side 1 of the 4 is the coil wire the website you sent me is for a regular cap this is a 4.3 vortec motor with computer timing not one you set your self the computer sets the timing on the motor i know how to set a normal distibutor i need a diagram for this type
Old 06-14-2009, 09:31 PM   #4
gchemist
gchemist's Avatar
Yea, the cap has the wires coming out the side. However, the cap only reroutes the current for rotation and side spark plug wire routing. Either way, the #1 pistion at TDC still points to the #1 cylinder like the older and small cap HEIs. Setting the timing is still identical. You can even use the mark on the harmonic balancer as a verification.
Old 06-15-2009, 05:56 PM   #5
lvschevytrucks
Unfinished Project Club
lvschevytrucks's Avatar
I dont think you can use the marks on the harmonic balancer for verifacation on these, Im in the process of doing the heads on my 95 4.3 and when I have the marks lined up the piston is way off top dead center. There are two marks but neither one work. and there isnt really a timming mark on the timming chain cover. Ive set the piston to top dead center and the dist. between 2 + 4 hopefully it will work
Handle every Stressful situation like a dog.
If you can't eat it or play with it,
Pee on it and walk away.
1996 Dodge Intreped ES Nice car great on gas
1993 Jeep Cherokee.
Looking for a swb chevy 73-87
lvschevytrucks is offline   Reply With Quote
Old 06-15-2009, 06:02 PM   #6
lvschevytrucks
heres a picture of the piston at top dead center.....no mark on the balancerName:  100_1565_edited.jpg
1993 Jeep Cherokee.
Old 07-11-2009, 11:38 PM   #7
gchemist
gchemist's Avatar
Originally Posted by lvschevytrucks View Post
heres a picture of the piston at top dead center.....no mark on the balancerAttachment 470072
FI motors have the crank mark at a different position. The position is shifted to the location of the crank sensor.
Old 06-21-2009, 01:02 AM   #8
purewhitemp5
Firing order on cap is as follows On pass. side of cap its 2 , 4 , 6 ,Coil wire on oppisite side its 3 , 1 , 5 so on drivers side the #1 plug is in the middle (On the distributor).
purewhitemp5 is offline   Reply With Quote
Old 06-21-2009, 02:06 PM   #9
lvschevytrucks
If you turn the cap over you will see it actually fires between #2 + #4
1993 Jeep Cherokee.
Old 06-22-2009, 04:27 AM   #10
JWOLVES
JWOLVES's Avatar
i put it between 2and 4 and it won't start i replaced the module it sounds like it wants to fire up but it's still off time or something i'm wondering if the distributor cam sensor is bad or if it jumped the chain there is a mark on the distributor looks like a #6 thats where i put the rotor between 2 and 4 #1piston TDC and nothing
Old 06-23-2009, 01:30 PM   #11
lvschevytrucks
not trying to highjack your thread, but im in the same boat as you are...I have mine set the same way as yours...nd Im also wondering what the six is...Id also like to know what the arrow on the front of the dist. for?
1993 Jeep Cherokee.
Old 06-23-2009, 03:03 PM   #12
JWOLVES
JWOLVES's Avatar
from what i can figure out the 6 is so you can tell the 6 cylinder from the 8 cylinder distributor and i think it's where the rotor button is suppose to face on the distributor as for the arrow in the front of the distributor i have not seen it thats what i think but not sure
Old 06-23-2009, 07:02 PM   #13
lvschevytrucks
heres a picture of the dist's arrow Im talking aboutName:  100_1679_edited.jpg
1993 Jeep Cherokee.
Old 06-29-2009, 10:41 PM   #14
JWOLVES
JWOLVES's Avatar
ok i'm tried to put on a new distributor today and i can't put it on the triangle mark on the distributor it will go 1 tooth ahead or 1 tooth behind i don't know what i'm doing wrong why can't i get it on the mark i move the oil pump shaft the way i do on all distributors i have installed but can't get it on the mark is there a special way to do this tryed this today for about 4 hours and gave it up for the day if someone can help me so i can try it again tomorrow
Old 07-10-2009, 06:10 PM   #15
lvschevytrucks
how did you make out....get it running, Let me know
1993 Jeep Cherokee.
Old 07-11-2009, 12:04 AM   #16
JWOLVES
JWOLVES's Avatar
yes i got it running at TDC i turned the rotor to the #5 plug wire on the cap well just a little before the 5 and it started right up how are you doing with yours did you get it together yet
Old 07-11-2009, 11:46 AM   #17
lvschevytrucks
the #5 plug wire... wow, so you didnt pay attention to the arrow or the little 6 on the dist. ?
Im almost ready to pop the Dist in, Been busy havent had much time Check out my thread you'll see where I am
http://67-72chevytrucks.com/vboard/s...d.php?t=349529
1993 Jeep Cherokee.
Old 10-17-2009, 11:36 PM   #18
latunguley
Guys?? Please?? If any of you get an email about my reply here? Please let me know i've been stuck on this distributor poblem for three days and nights now. I need some experienced help. I can't seem to find a crabk position and or distributor spot that fires the plugs. I have spark, have fuel, have alot. Just don't understand what the heck is wrong here. Had issues dropping it in on the number 6 inside the distributor cap but got it right before the number 6 like within a quarter inch of the arrow. Please anyone out there?
latunguley is offline   Reply With Quote
Old 10-18-2009, 07:33 AM   #19
68C15
blood type; Retumbo
68C15's Avatar
AutoZone has alldata. they have a procedure for this. unless you follow it you might as well throw the dist. in the glovebox.
have them look it up under
powertrain management
ingition system
service and repair
distributor installation
BTW, I remove the factory limiter for dist. rotation and install a dist. clamp for a Chevy small block. but here is the clincher. you NEED a scan tool to set the cam retard. specs are 0* +- 2* @ 1000 RPM
68C15 is offline   Reply With Quote
