05-25-2010, 10:52 AM | #1 |
IT Guy/ Father/ Chevy lover
Gas tank relocation
I did some searching and couldn't find anything on if anyone here has upgraded to a larger fuel tank and mounted it where the spare tire was. Its an idea I've been throwing around since I'll more than likely be running new fuel lines in the next month when I drop my motor in the truck. Any pictures would be great too!
78 Chevy (Pictures) SOLD 79 Chevy LWB (pasture) 83 Chevy LWB (crushed rusted beyond repair) 02 TrailBlazer SOLD 03 VW Passat wagonSOLD 95 extended cab silveradoSOLD (still in family) 05 Crew Cab Silverado 5.3 (The Turd) WTB: 66 El camino Technology Specialist aspiring to be a gear head. |
05-25-2010, 10:59 AM | #2 |
Re: Gas tank relocation
You might put the words Blazer gas tank in your search. There have been some on here that have relocated the gas tank on their pickup using a Blazer gas tank.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
05-25-2010, 11:06 AM | #3 |
thanks doing a search now
05-25-2010, 11:26 AM | #4 |
www.73-87.com is a great resource.. in fact I found exactly what I was looking for..
http://www.captkaoscustoms.com/blazertank.html
05-25-2010, 11:27 AM | #5 |
You sir are the man!!!!
05-25-2010, 12:35 PM | #6 |
Glad I could help... Isn't this a great site?
05-25-2010, 09:28 PM | #7 |
i got an aluminum 19 gallon rear mount tank from performance online and installed it
05-25-2010, 09:29 PM | #8 |
it is all so a bed fill one as well but i think that they have side fill ones i think
05-26-2010, 02:10 AM | #9 |
78 Big10 454
Wiggles, you might want to search the Transfer Flow website for a large capacity fuel tank for your p/u. My swb C-10 with a 454 came with a single 16.5 gallon saddle tank. Go figure.... That got me around the block before I had to fill up. I swapped out the small saddle tank for a Transfer Flow 26.5 gallon tank kit that sits where the spare was. I still use the stock fill on the passenger side. What a difference an additional 10 gallons makes.
05-26-2010, 10:21 AM | #10 |
hmm I'll have to check that out thanks for the tip it would be nice to be able to keep the fill in the same spot
05-26-2010, 11:21 AM | #11 |
Crew Cut
heres a blazer tank
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
05-18-2018, 04:57 PM | #12 |
How many gallons? I'm looking for a lower profile gas tank on my C10 I believe the one I have is the 41 Gal which hangs way too low!
05-18-2018, 07:02 PM | #13 |
Boyd welding approx. 19 gallons dimensions 26.5x19x10
with 3 Baffles |
Tags |
fuel, fuel tank, gas tank, relocation |
