![]() Join Date: Apr 2008
56 vin locations
Got this 56 panel, no vin in the door jam area. Did they put them anywhere else on the truck?
Re: 56 vin locations
the top of the frame close to the steering box. and one on top of the frame under the cab on the drives side. but you can't see that one with out removing the cab.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
thank you sir, ill have to check on it tomorrow.
Well i got this number off the frame in front of the steering box. Doesnt jive with anything ive found regarding the vin number for this truck.
560003394 Doesnt tell me anything. |
#5 | |
Ray Last edited by raycow; 05-30-2010 at 11:51 PM. |
#6 | |
I could just start running vins until i get a match maybe? |
All I can find on that # is it's a 56 that was made in KC Mo. The tag that was on the door post would have had a 3a or 3b on it or some thing close telling if it's was a 1/2 or 3/4 ton and what wheel base it is. For some reason they didn't stamp that part on the frame.
yea my 56 pickup had that info on its vin. So could we fill in the blank and have a complete VIN that i run through the DMV?
Do you have the title or last reg.? That should work. The dmv probley told you that that # was to short. There just not used to see old truck VINs. Don't know how it works in Tx. but I have heard the girls behind the desk at the DMV in Ar. talk about over riding the system and making it take it.
Cancer Survivor in the making.
I think this is a case where it would be helpful to make sure everyone understands the truck was not produced with a VIN. VIN is a legally defined serial number system that didn't start until the early 80's. If DMV is expecting to match that structure it just isn't going to happen.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron. Steve@OldSub.com OldSub.com . MaxwellGarage.com . OldGasTowRigs.com |
no im trying to find out who the last registered owner was. I do not have the title or apparently a VIN. If i can come up with the vin i can get a name i can look into. I was told the truck was driven up until 1998. They also told me that they got the truck from a friend and that they had the title. They called me asking for the VIN as apparently the friend has two titles for 56 panels.
I called today and left a message of what i had hoping they can match it up. However id rather just go around the people i bought it from as they do not have the title themselves. They told me they would have to ask before giving out their friends numbers and i havent heard back. This was over a week ago. |
#12 | |
It didn't work out very well. The guy was never able to produce a title for the truck. Whether the story was BS or he just didn't care was never clear to me but I was stuck with a truck with no paperwork. In this state that is not an easy thing to deal with but I found a way. And I got a lot of useful parts off that truck that I actually only paid $50 for in the end. It was a panel and I sold the original buckets for for more than that.
Not try to be a wise guy but sounds like something that should have been done before $$ changed hands. In Ar. you can get a title on a bill of sale on something that old. But it has to have the VIN on it. or what ever you want to call the # on the a-pillar and the frame. Soulds like you will have to sweet talk the folks you bought it from, because that's the only # that is on that truck.
http://www.stovebolt.com/techtips/vin/vinbuster.html put what you have here
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway Last edited by blackdiesel; 05-31-2010 at 12:21 AM. |
#15 |
wow thats cool!
Ok so we are missing model and wheelbase. Do we know the vin codes for those? is the panel the same wheel base as my 56 shortbed pickup? Intresting that k or 0 gives me a kansas plant. Vin off my 56 short bed big window is v3a56k023856 I used the 3a added to the numbers i had (560003394) to get the model and wheelbase but then it said none for the plant. Without the added on numbers it came back as being from kansas. Must be a different prefix for the panels Last edited by Slammy; 05-31-2010 at 12:32 AM. |
#16 |
Slammy,
You have bigger problems than not being able to find the truck in the DMV database. Here in Texas, the DPS can and will confiscate your truck if it does not have a factory affixed VIN tag, on your 56 that means it MUST be spot welded to the door jamb, not rivetted or screwed on. You need to get with the local DPS and get a state assigned VIN tag. It's a bit of a pain in the butt to do this but you don't risk loosing your ride this way. I had to go this route on a '57 panel I had a few years back. A close friend of mine is a Sgt. with the DPS in charge of vehicle theft. He's the one that set me straight on this. Rob in West Texas |
#17 | |
Anybody know prefix code for a 1/2 ton panel? I was told what city the supposed last owner lives in so if i guess and get it right then maybe i can get a title that way. Last edited by Slammy; 06-11-2010 at 01:55 AM. |
#18 |
So now we have a truck with no title or good serial no AND and altered/defaced assigned # issued by a State agency? This is going to get interesting. I'd start getting notarized affidavits from previous owners stating who they bought and sold it to, or copies of previous bills or sale to sort this out.
#19 |
What is this panel worth? Does it run and drive? And how much are you planing on selling it for? I'm guessing quit a bit sents your going though this much trouble. Not trying to be a jurk just asken.
#20 |
Hollister Road Co.
Trucks with the paper history that this one has are a parts trucks. It could easily cost $400 to get it titled, if it doesn't turn out stolen, salvage, or some other title encumberment.
#21 |
hahha you guys are so dramatic! OH NOESSSS whatever will i do hahah.
Ill drag it to the front of the shop and jack the body up and get the vin under the cab and see if i can do anything with that. If not, ill just take the parts i need off it and cut it up i guess. Not the end of the world. |
#22 |
Dramatic huh? Someone remind me to ignore this guys posts from now on.
#23 |
I was kidding...jeezz lighten up fellas.
