Parking brake parts and advice.
Alright, I have had a dilemma for a while with my parking brake. I have the style that comes up next to the stick and the brake drum and assembly is coming off of the tailshaft housing on my transmission. My issue is is finding parts for it because I drive for a while the drum starts catching on the brake band when it's fully released. Anyone know of anyone who has extra parts or is a vendor to this particular area of the trucks?
That's the thing about a Chevrolet, no matter how they look, whether it be a trailer queen or a good ol' used farm truck, no other truck on the road will always look that damn good wearing a Bowtie. |
![]() Join Date: Aug 2013
Re: Parking brake parts and advice.
can you post a pic of part in question. i have a 65 and they had 2 versions so yours may need to be identified first then some members can help solve this issue, gotta have them working brakes!!!!
This is the style. Unfortunately I don't have a pic of the underside of the truck with the assembly.
looks like a bus brake, havent seen that one before. if the underside is the same as most then its just a simple handle. anyway ima look at some of my books a try and help, if you can get the underside that would help even more...
Is your truck a 3/4 ton, do you have a round housing on the back of the transmission that has a band brake on the transmission. Most 1/2 tons have a lever assembly on the transmission crossmember that then engages via cables the rear brakes, Yours appears to be different than the normal 1/2 ton park brake.
Heres on on ebay now. http://www.ebay.com/itm/1963-CHEVROL...efc431&vxp=mtr
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#7 | |
1936 Chevrolet 1/2t 1964 Chevrolet C10 1964 Chevrolet C10 (sons) 1965 Chevrolet K10 Suburban 1969 Chevrolet C10 1937 Plymouth P4 |
Theres a bag of parts included with the brake above....I'm not familiar with them mechanically...but I've seen a few.
My Dad drove for the city in the 70s. They had Dodge dump trucks he would complain of those style parking brakes catching fire on them.
Yes I have a 3/4 ton truck. It is a round housing drum.
Yeah I need to probably re adjust mine but I know that the drum is warped. I need a brake shoe for it because mine seems to be adjusted all the way when it's set it's tight, but when St I'll be parked on a hill and it will roll a little until I h old it all the way back so I use the reverse gear brake.
![]() Join Date: Mar 2013
Interesting set up D Rock...I've never really seen that before. I did drive a 65 GMC 1 ton military truck that had a similar brake...except the handle was on the left side of the stick. Don't much remember what the underneath looked like...been almost two years since I seen that ol GMC. Anyhoo hope you get that fixed!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
here is what you should have. sorry but i had a dumb moment years ago and gave away all my old chevy parts books
same as mine, but iam looking for the banding material
#15 |
![]() Join Date: Sep 2011
That's the style on my 66 C30, I got a replacement from Tony at 4-5-6 Chevy trucks. I also have a local buddy/ pro mechanic that says he can get some.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
#16 |
yea mine has same setup, will be looking to get it fixed
#17 |
Same here. I rebuilt the band using friction material from McMaster-Carr. Also, the 1963 shop service manual does a good job covering the adjustment.
#18 |
60-66 Nut
What did you use for the rivets?
#19 |
I used brake and clutch lining rivets bought online from Hanson Rivet. Here's a site that'll give you an idea of what it takes to re-line the band brake.
http://www.jdcrawlers.com/messageboa...r=asc&start=15 |
#20 |
this is great thank you for taking the time to show us what it takes to improve on a job, it looks great.
#21 |
ok so looking at chevy trucks pictures, mine is different, mine is like cg285's picture, I still think I could use the parts to make mine work, thanks for the help and information
#22 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Could you perhaps upgrade it to something like this?
#23 |
ok so do you have a link as to where we can go and see what will replace the old style of e brake?
