12-09-2014, 08:33 PM | #1 |
SAVING ONE TRUCK AT A TIME
1961 Crew Max
Well here it goes. Found this beat down 2003 d-max on craigslist for a good price and decided to try and put it in a 61 crew cab. The crew cab has been for sale for a long time. It should be here around the first of january. Will post more pics once it gets here. Thanks CHIZZLER
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
12-09-2014, 09:36 PM | #2 |
1961 crewcab
Re: 1961 Crew Max
wow! that blue crew has been for sale for a long time, it is one of the first ones I found pics of on internet searches for crews.
looks to be a neat build!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
12-09-2014, 09:49 PM | #3 |
Re: 1961 Crew Max
Will you try to reuse the 61 body on the 2003 frame or move the DMAX to the 61 frame?
12-09-2014, 10:07 PM | #4 |
Re: 1961 Crew Max
LB7 / 5speed
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
12-10-2014, 12:25 AM | #5 |
Re: 1961 Crew Max
I think what im gonna do is find a 64 and up frame and ditch the factory torsion/x frame. i know we will have to stretch the new one. I figured it would be better to find a complete running d-max truck as a donor. This truck i found has 200k and the owner seems to remember spending around $4k at about 130k. Im hoping injectors but until i get it cleaned and plug it in i cant tell.The transfer case is shot but im going to convert to 2wd so that dosn't matter. There is lots of details to work out so im going to work on getting the chassie mocked up first then test fit motor and trans. Probably talk to the crew at porterbuilt and see what we can do.chizzler
12-10-2014, 01:07 AM | #6 |
Re: 1961 Crew Max
watching this build
1961 Apache 10 with side trim 1964 4 door crew cab C20 1966 Chevy Suburban with custom trim 1961 K30 with a 4-53T Detroit diesel 1966 GMC 4X4 Suburban |
12-10-2014, 01:18 AM | #7 |
Re: 1961 Crew Max
Should be an interesting project.
"It ain't as easy as Chip Foose makes it look" |
12-10-2014, 01:23 AM | #8 |
Re: 1961 Crew Max
I'd try to put the 61 body on the new frame if at all possible, even if it requires stretching the frame and channeling the body over it.
12-10-2014, 03:19 AM | #9 |
Re: 1961 Crew Max
12-10-2014, 04:00 AM | #10 |
Re: 1961 Crew Max
I'm In Can't Wait.,,
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
12-10-2014, 09:35 AM | #11 |
Re: 1961 Crew Max
this should be an interesting combination and end result ....
what is the late rated for mpg's ....???
dont want to hear excuses, i want to hear solution(s) |
12-10-2014, 10:40 AM | #12 |
Re: 1961 Crew Max
this truck had 14.4 estimated mpg on the dash computer.
12-10-2014, 01:45 PM | #13 |
Re: 1961 Crew Max
Cool project. I daily drive a 2006 Duramax and have since new. Would love to put a complete drivetrain in one of these.
I have a longggggggggg step side 3/4 (or 1 ton) GMC I just bought and hauled home last week. Hummmmm?
"Life is too short to drive a boring vehicle". Later, Wayne |
12-10-2014, 08:21 PM | #14 |
Re: 1961 Crew Max
Sounds like a great project, I will be watching
12-10-2014, 08:24 PM | #15 |
Re: 1961 Crew Max
Cool project. I'm looking forward to the build thread.
It only has original paint once |
12-10-2014, 08:27 PM | #16 |
6>8 Plugless........
Re: 1961 Crew Max
Great project! I personally don't like body swaps on newer frames, but that's just me. If you plan to drop the truck, that newer frame will be hard to do any way I think because the frame drops so far down under the cab it would kill your lowered stance without the floors getting raised to compensate for it..
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-10-2014, 10:57 PM | #17 |
Re: 1961 Crew Max
I plan on using a 64-66 long bed frame and ditch everything else. The frames on the Hd's hang way low for that big old allison. thanks all for checkin in. CHIZZLER
12-11-2014, 01:30 AM | #18 |
60-66 Nut
Re: 1961 Crew Max
That's what I would do as well. Those '88 and up frame swaps just do not work out well IMO. Just a FYI, a '63 frame is the same as the '64-'66 frame.
12-10-2014, 11:11 PM | #19 |
1961 crewcab
Re: 1961 Crew Max
I found a frame for one I was going to build that is probably the perfect style to look for.
it was a 66 c/30 factory flatbed, it has a 133 inch wheelbase, the frame rails are about 3 inches taller through the center because it is a 1 ton, and it has a leaf spring rear. the extra 5 inches would work nice between the rear wheel and the cab, not so short looking like the 127" wb. I am pretty sure your current crew is like mine , which is a 141" wheelbase
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 12-10-2014 at 11:23 PM. |
12-11-2014, 01:45 AM | #20 |
Re: 1961 Crew Max
Thanks for the info. There is a 1 ton dually i got my eye on right now local. Not sure what he wants for it.
12-11-2014, 02:01 AM | #21 |
Re: 1961 Crew Max
I also have my eye on this truck. It looks like it has pretty good sheet metal and bed. It's also a half ton.
http://portland.craigslist.org/clc/cto/4789822543.html
12-13-2014, 03:48 PM | #22 |
Junior Member
Re: 1961 Crew Max
Cool Crew! Its crazy, I found this crew cab in Saratoga, Wyoming back in the 90's when I was doing construction there. The guy also had another 64-66 cab. I called back a couple years later and he said it all sold and went to the west coast somewhere. Glad too see it is finally getting some love.
1969 impala conv 427 #s loaded. dad bought new 1969 "Judge" RA-3, rare warwick blue/white, #'s 1968 vet convertible #s 427/435 tripower (sold) 1968 belair 2door post #s 427/385 1936 ford 5w coupe dads 1st car 1969 camaro ss (17,xxx) miles Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project. |
12-14-2014, 01:25 PM | #23 |
Re: 1961 Crew Max
Update. Yesterday i got the d-max all cleaned up any everything i could pull apart and keep it running. Im looking at stand alone wiring kits and have no intention to spend $1000 plus dollars. anyone build there own?
12-14-2014, 11:47 PM | #24 |
Re: 1961 Crew Max
The Ls engines are pretty straight forward.
The duramaxes have 2x the wiring. I think you'd start the same way you do with an LS swap. Get the computer flashed to turn off all the stuff thats not required for your swap. Then take the entire harness out and remove whats not needed and re-loom it all. |
12-15-2014, 01:18 AM | #25 |
60-66 Nut
Re: 1961 Crew Max
You might post that question in the 'Diesel Conversions' section of this forum.
