12-27-2017, 07:03 PM | #1 |
WTB Looking for frame bracket for z bar
Looking for the clutch bracket that sits on the frame which supports the z bar.
I believe it is riveted from the factory. A PO on the 65 I just picked up did a crappy job of welding one in the wrong position. Instead of fixing it correctly, they proceeded to cut a bigger hole in the floor so the pedal linkage would clear. If anyone has one please post pics & price. Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
12-27-2017, 09:47 PM | #2 |
One foot in front of the other
Re: WTB Looking for frame bracket for z bar
Almost positive I have on off a '65 that is still on the frame. Will be this weekend though before can check though.
12-27-2017, 09:53 PM | #3 |
No hurry on my end, wont b till spring b4 I can work on it.
Appreciate u checking.
12-27-2017, 10:01 PM | #4 |
Found a pic- This what you need correct?
12-27-2017, 10:04 PM | #5 |
yupper, the piece on the frame just above the shock.
BTW will u be cutting up the frame? Will also need a support bar that goes across the rear frame rails. Its the one the panhard bar bracket is right next to. I can post a pic tomorrow.
12-27-2017, 10:11 PM | #6 |
Yes I will. A guy is supposed to come get the bed this weekend.
12-28-2017, 12:44 AM | #7 |
The support I need is the 1 just after the rear in this pic (could also use the panhard bar diff mounting stud).
Hope that helps. Thanks
12-28-2017, 08:59 AM | #8 |
Just so I am clear, You mean this one?
12-28-2017, 11:08 AM | #9 |
yupper
12-31-2017, 12:48 AM | #10 |
Cut out the z bar bracket today. Will see about the other pieces on Monday. Also sent you a PM about patch piece you were asking about in other thread.
