08-28-2019, 09:49 AM | #1 |
Starting 1966 Factory Short Bed Build, Bagged, 383 Stroker and Muncie M20 4-Speed
I just completed a 1969 C10 build, ground up with 5.3 LS and 4L60E. Now, after very recent Divorce, I was able to pick up a 1966 Factory Short Bed for a great price to build.
Plan is complete ground up build. Full roller 383 Stroker with FiTech Fuel Injection, rebuilt M20 Muncie 4-Speed, 3:42 Posi, Flat Red Wrap with Black highlights. Updates to come. Any comments are welcome. |
08-28-2019, 10:22 AM | #2 |
Re: Starting 1966 Factory Short Bed Build, Bagged, 383 Stroker and Muncie M20 4-Speed
Save yourself some heartache down the road and steer clear of Fitech. I'm speaking from experience. Good luck with the build
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
08-29-2019, 09:06 AM | #3 |
Jhrusk,
I would sway away from them honestly, but i bought the full kit, all of it 2 years ago, played with it a bit on the 383 early on in my "69 build, i then changed direction and went to LS, so this build i figure i have the system, so ill give it a shot. But i can honestly respect what your saying and trying to help, but i figure i have it, so ill try it. Easy to go back to straight Carb. |
09-19-2019, 09:39 AM | #4 |
Update:
Took 1970 350ci 4-bolt main into machine shop. He was able to clean it up, but he had to go to .060 overbore, making this a 388ci stroker build. I am not happy, only because i already had .040 overbore stroker pistons, so now i have .060 speed pro pistons and rings showing up tomorrow. Oh well... Hope to be in the 450hp range. 388ci stroker, roller cam and lifters by Howards, roller rockers by Comp Cams, Edelbrock RPM aluminium heads, RPM Intake, Mallory Ignition, and as i stated earlier maybe try the Fitech i currently have or just go with a standard carb. |
09-19-2019, 09:55 AM | #5 |
update 2:
I have read about a few on here going with air bags. There are a few company's out there that have kits designed for C10 that i found. There are some extremely expensive kits, some good priced, and some supper cheap ones. So i found 3 that i have heard about and sent out email requests. one that i will name here is Grunions. Anyways, i got no response from two (one being Grunions) and one i sent the email to the wrong address. So i called Grunions, spoke to young man there who after asking a few questions to him, i noticed he was way to important to be talking with me and then i asked about ordering a kit and he told me that they are too busy now to take my order. I was so blown away by this response! he says let me get your number and ill call you in the next couple days and get your order. After 2 weeks, i was beyond pissed, I called EZ Air Ride. I heard about a guy there named Steve who is the owner and will talk with about your project and steer you to what he thinks is the best and why. So i talked with Steve for 30 min. about my project, what i wanted listened to him and his suggestions. he never tried to steer me to the high end kit! He was just a great guy to talk with, so needless to say, i order my kit from him. He is in Cali and it was on front porch (Washington State) in 4 days. Each part was separately wrapped, and well packed. I have yet to install it, but DAMN he has great customer service. Now recently i learned that there may be a sponsor on here that does bag kits. I am sorry i did not find them before i ordered my kit as i like to try to support anyone who is a sponsor of the site. With all that said, i hope to be test fitting all the stuff onto the frame in the next few weeks. Pics coming...... |
09-19-2019, 10:00 AM | #6 |
Update 3:
Sorry for all the messages so quick, been helping my mother through the death of her husband. The cab completely stripped and is off the frame on the roller box. The frame is without a motor and this weekend will be without a tranny. going to remove existing suspension, clean it up and start test fitting the air bag kit, shock relocations, and such. Need to cut in the C-Notch, fab up the new shock mounts, weld on the bag plates and such. After that, i have 5 quarts of Por 15 that will be applied after i sand blast the frame. Pics coming.... |
09-19-2019, 03:35 PM | #7 |
pics at the start
02-17-2020, 12:29 PM | #8 |
my first powder coating projects
02-17-2020, 12:45 PM | #9 |
March Pulley serpentine belt conversion
02-18-2020, 12:12 PM | #10 |
Why modify that PS pump? The newer remote reservoir pumps are smaller and easier to plumb.
Our 1965 GMC big block pro mod build http://67-72chevytrucks.com/vboard/s...d.php?t=746098 |
02-23-2020, 11:39 AM | #11 | |
Also, i have never worked with the newer style pumps. |
02-25-2020, 02:33 AM | #12 |
Howdy,
Tried to send you a PM, but apparently your inbox is full. I was curious what was included in your rebuild kit and where it came from if you don't mind sharing? I am considering picking up a 4 speed, but it has some damaged/chipped teeth on a couple of the gears. Because of that it is a stupid cheap price from what I have seen, but not sure about getting some of the internal hard parts. Thanks much!
No bolt or nut in the world will remain tight if you turn it to liquid!!! |
02-26-2020, 10:27 AM | #13 | |
Sure i will share. I bought the book: Workbench how to rebuild a Muncie 4-Speed by Paul Cangialosi. I also went to youtube and looked up Paul Cangialosi and he has a bunch of vidoes on howto. He is is basically the Godfather of the Muncie. He supports/owns a company that sells the parts - 5speeds.com. Everything including buying complete Muncie from them. If you have any questions, please let me know. |
03-28-2020, 08:41 PM | #14 |
updates: This is the frame brace kit from Summit Racing, i finally got it in
03-28-2020, 09:41 PM | #15 | |
Thank you very!! Your truck is coming along great, quality work!!
03-28-2020, 09:48 PM | #16 |
Thank you big daddy
03-28-2020, 10:15 PM | #17 |
60-66 Nut
Looking good and making some nice progress.
03-29-2020, 12:32 PM | #18 |
Thank you sir! Means alot coming from you. B
I must say, thank you for all the parts you build us! They are awesome and stand alone compared to others. Note: it does help if you buy the correct power steering box. Lol |
03-29-2020, 01:24 PM | #19 |
I just checked out your build thread. You've got some very cool fabrication going on. Very impressive.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
03-29-2020, 09:05 PM | #20 |
What are you going to do to enclose the battery? In that location it is likely to be pummeled with water, mud. rocks, or at minimum tire rubber (which is really nasty to clean up).
03-30-2020, 07:10 PM | #21 |
Thank you sir, i really appreciate it. I am just trying to have some fun, share the progress and hopefully help any one else with theirs if i can and keep my mind going during all this crap on the virus.
03-31-2020, 10:04 AM | #22 |
loving this
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
03-31-2020, 10:19 AM | #23 |
Thank you. I try to keep the updates coming. I am working from home and sometimes that is more difficult.
Anyways, got the rearend back from rebuild, so it is going in this weekend along with front end. I need to get rims and tires for this thing, but struggling with what to put on, transit rims in red or black OR go with a set of Riddlers. Truck will be body in flat red wrap, with accents of black. |
03-31-2020, 11:24 AM | #24 |
---- Also seriously thinking about moving the battery box to under the cab, now is the time to do it if i am going to. lol
04-02-2020, 01:27 PM | #25 |
Looks so good. I'm jealous of the frame, and really liking the brace kit.
