Frame question 1/2 ton vs 3/4 ton
I have a 1/2 ton long bed 4x4 and I was wondering if it's worth it to you upgrade to a 3/4 ton frame I have 3/4 ton axles and springs. Going to be doing some towing. Any thoughts or advice thanks
Joe |
Re: Frame question 1/2 ton vs 3/4 ton
I think the frames are the same on the 4x4 1/2 + 3/4 tons.
As far as towing it depends on where you draw the line. If its a ocasional 7000 pounds i don't see it worth the effort. If it is alot of towing, and closer to 9000 pounds then a 3/4 ton will be the ideal choice. |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
The frames are the same.
What are the 3/4 ton differentials you have out of?
60-66 Nut
I've never had a K20 but the C10 and C20 frames are not the same. The C20 is stamped from heavier gauge steel and has extra bracing.
#5 | |
I guess I was repeating what I heard without knowing for sure myself. Thank you.
Thanks y'all
Will be towing about 7000lb |
Found this in another thread:
½ ton 2WD: 6-1/32 x 2-1/2 x 5/32 ¾ ton 2WD: 6-1/8 x 2-17/32 x 3/16 One ton 2WD: 8-1/8 x 2-13/16 x 3/16 ½ ton 4WD 115” WB: 8-1/32 x 2-25/32 x 9/64 ½ ton 4WD 127” WB: 8-1/8 x 2-13/16 x 3/16 ¾ ton 4WD: 8-1/8 x 2-13/16 x 3/16 As you can see, even the ½ ton 4WD long bed uses the same size frame member as the one ton 2WD. 1960-62 frame ,measurements ½ ton 2WD: 5-15/32 x 2-1/4 x 1/8 ¾ ton 2WD: 7-3/16 x 2-3/4 x 3/16 ½ and ¾ ton 4WD: 7-13/64 x 2-3/4 x 3/16
Could someone please verify that the frame for the 4x4's are actually 8 inches tall?
I can check tomorrow ,66 K 20 4x4 and let you know.
Confirmation: My 66 K 20 frame is somewhere between 8-8.25 measured from about the center under the cab. Didn't want to roll around in the snow to check further!
Thanks.
I wonder if they made the frame taller because a 4x4 may need to resist more twisting.
