Old 04-04-2021, 08:26 PM   #1
hatzie
Moderator
hatzie's Avatar
DIY valve cover mod to address Oil consumption for LS motors.
This guy shows how to modify the valve cover baffles to enhance the oil vapor separation and drainback the oil rather than ingesting it into the intake.
http://youtu.be/CePGNsAkcYQ
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-05-2021, 09:46 AM   #2
bigd65
bigd65's Avatar
Re: DIY valve cover mod to address Oil consumption for LS motors.
I just watched it... great video. Do you happen to know what years this might be the problem... now I'm wanting to remove my covers and check
2004 Silverado Crewcab (Dark Spiral Gray)
bigd65 is offline   Reply With Quote
Old 04-05-2021, 05:22 PM   #3
Boog
laying low
Boog's Avatar
There are a number of videos I've watched about this oil consumption "fix". A couple of guys say there is a later GM version of valve cover with a bit different baffle. I wonder if a guy could insert some wire mesh into the large opening of the valve cover baffle to separate oil and air at that point much like the pre pcv engines of old had in their crank case breather/oil fill caps.
Also there are a number of guys adding oil catch cans into the pcv system. Pretty simple. Google oil catch cans and you'll find a few vids out there on that too. I bought a new pcv valve for my 03 Tahoe and was surprised to find it is a hollow case only. There is no check ball inside so it pulls engine oil vapors full time. If it left GM that way it has to be right, right? My Tahoe with 265,000 miles leaks way more than it uses I'm sure. My 09 Yukon with 180,000 miles uses oil. A quart or two between changes and it has that dreaded cylinder deactivation feature that is said to be a cause of oil consumption as well.
You can find videos on youtube on how to fix most anything in the world it seems so you be the judge.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-05-2021, 07:39 PM   #4
hatzie
Moderator
hatzie's Avatar
It's mostly the AFM engines that have a reputation for oil consumption.
If you aren't loosing oil then I wouldn't worry about it.
If it works it's free. If it doesn't work you're no worse off than you were before drilling the holes in the baffle.
