12-07-2023, 10:50 PM | #1 |
is this long or short
Hi all. I was thinking of buying this truck and the owner has told be it is a short bed, but looking at the pictures, it's hard to tell. It's a 4 hour drive to go look at it. What do you think.
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James |
12-07-2023, 11:17 PM | #2 |
Re: is this long or short
Both Pictures are in a (trigonometry) view.
A lot of sellers do this. Here is the Specs for Square bodies 73-87 stuff MODEL Wheelbase (6') Wheelbase (8') Blazer 106.5" C10 117.5" 131.5" C20 N/A 131.5" K10 117.5" 131.5" K20 N/A 131.5" C30 N/A 131.5 Crew Cab N/A 164.5" Suburban 129.5" Regular Cab Cab & Chassis 135.5" 159.5" 159.5" C/30 Motorhomes 127" 158.5" 178" You got choices. Ask the person to measure the WB. The VIN# can tell you alot. Or drive and look at it. If it is a good price, you may regret your hesitation.
12-07-2023, 11:29 PM | #3 |
Looks like a long bed to me. Below is a short bed. Similar angles. Gap between front of rear tire and rear cab is less than a door length on swb. Looks longer on truck you posted.
12-07-2023, 11:35 PM | #4 |
Great Pictures and Comparision.
12-08-2023, 10:19 AM | #5 |
Thanks that's a good way to have him take a look at his. I sent him this picture and info. I'm also asking him for a side shot.
12-08-2023, 10:17 AM | #6 | |
12-08-2023, 11:25 AM | #7 |
We confirmed it was a long bed. He said it was short,,,, then said it was long. That was almost a 4 hour pointless drive.
12-13-2023, 11:01 PM | #8 |
Looks like it was a long bed that the rear portion of the frame was cut when the flat bed was installed to make a "short bed"
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
