P0174 and P0171 codes
I keep getting these codes on my LS swap. Its an LQ9 stock other than headers and a cold air intake that I fabbed myself. I'm using the PSI conversions computer and harness. I put a fuel pump in the stock tank, and it's getting 45 psi at the fuel rail. But- it was a cheap pump off of Amazon and I have suspicions that it is the culprit of my codes. The engine has 3/8 supply and return lines.
Do I replace the pump or look to having it tuned?
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '19 Chevy CC 4x4 Duramax Dually |
Re: P0174 and P0171 codes
Those are lean codes and if your only at 45psi your running lean. I believe gm wants 55-60psi at a minimum. Corvette regulator most guys use is preset for 58psi. Where's the regulator on your setup?
67 C10 2wd Stepside (to be fleetside), Factory AC truck, Big Back Window, just got a 6.0/6l90e to jam in it now..... Needed: paint and lots of it. and i'm sure lots more misc. parts. Project 67 short step Build Thread 01 Sierra Crew 6.0 2015 Ford F150 Work gave me truck i really wouldn't buy a ford. |
Well, that is probably my issue. The pump is only putting out 45 psi. I'm using the stock regulator that is attached to the intake, the engine is out of a 04 escalade. Guess I'll replace the pump this weekend and see if it helps.
