09-18-2021, 07:43 PM | #1 |
Smaller/thinner rear brake drum? Deep rear steelies won't fit!
So we're working on a cool ol '82 sab, and the truck came with a brand new set of custom deep 15" steel wheels that we're really anxious to get installed...but they're just barely not fitting!
Our existing rear drum brakes have a drum with a tall exterior lip that is just BARELY keeping the rear wheels away from seating as they should be. Does anyone know if we can get a slimmer rear drum? Or do we have to convert to disk brakes to get these bad boys installed? Hopefully you can see what we're up against in these images: |
09-18-2021, 08:14 PM | #2 |
Re: Smaller/thinner rear brake drum? Deep rear steelies won't fit!
09-18-2021, 08:20 PM | #3 | |
Do I need to swap them out as well, you think? |
09-18-2021, 08:37 PM | #4 |
I'm afraid that the remaining half inch might really make a right difference in that rear wheel well.
The wheels are 10" wide, so it's going to fill that rear wheel well completely, I think. Width-wise that is. |
09-18-2021, 08:37 PM | #5 |
09-18-2021, 11:25 PM | #6 | |
However, I think we'd be bumping up against the outer fender lip - or darn close to it. Wondering about the brake drum option. Anyone know if I can get a flat-topped brake drum? |
09-19-2021, 12:47 AM | #7 |
Define BARELY. Is it the whole height of the raised rim or just a 1/8 of an inch or so? If in is really BARELY, maybe you could have the fraction of an inch machined off. Taking off too much might weaken the drum too much.
For some years, there were different sizes of brake systems depending on GVW rating. If you have the larger one maybe you could sub the smaller set in its place. |
09-19-2021, 01:43 AM | #8 |
Auto parts stores have .250 wheel spacer in stock so you could try them, FWIW
09-19-2021, 11:18 AM | #9 |
Bring your drum down to the parts store and compare to a new one. That doesn’t look like an OE drum.
09-19-2021, 10:22 PM | #10 | |
I'll see if my local parts guys can find something different. The spacers are a great thought, but I think I'll need that additional quarter inch if I can figure out how to get these wheels to fit over that drum. |
09-20-2021, 08:37 AM | #11 | |
Just here to tinker
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
09-20-2021, 10:04 AM | #12 |
the diesel had the hd brakes. you will need backing plate out to convert to the thinner brake shoe setup. I'm sure someone will trade you.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
09-20-2021, 04:27 PM | #13 | |
I see the kits for $350ish just after a very quick and dirty search. I'm guessing that to swap from the backing plate out would be close to half of that, if not more. Might be a good time to make the leap? Any thoughts? Anybody tackled this swap recently? |
09-20-2021, 11:09 PM | #14 | |
From a quick check on Rock Auto, I see two different rear brake widths....one is 2" wide, and the other is 2 3/4" wide. I bet that's what I'm up against! So can I just swap the shoes and the drum, you think? Or will I need to swap everything from the backing plate out? That's an interesting question....one that I'm afraid I'll just have to dive right into before figuring it out. I'm guessing that's the hiccup I'm up against at this point. I'll know more, soon enough! |
09-21-2021, 05:27 AM | #15 |
The backing plates are different also. I was going to up grade from the 2" to the 2 3/4 and I would have had to swap backing plates.
09-20-2021, 12:30 AM | #16 |
Ok looking at your wheel is the lip of the drum folded part of the rim that is not weld. If so just grind the fold lip of the inner rim none welded off. Because it looks like it taking up about 3/16 to 1/4" of space of room compared to the weld lip.
The rim's may not be made for C10-1/2Ton direct bolt on. Try to lay the drum line up with the lug holes flat if it hitting those lips then the the fix. Or take it to a shop get it done.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
09-20-2021, 06:55 AM | #17 |
There were at least two different size brake options, but it was the width of the shoe that changed, not the drum diameter. I don’t think that helps your situation.
09-20-2021, 04:51 PM | #18 |
I would buy 1 replacement drum and try it and see if that works first.
09-20-2021, 07:44 PM | #19 | |
For that matter, I could toss one of the rear wheels into the truck and run it down to the parts store. A quick test-fit of the different style rear drums would let me know right if they would work or not. Good ideas! |
09-21-2021, 08:48 AM | #20 |
Can a guy even order just the backing plates?
EDIT: looks like the backing plates are readily available, if I can just figure out which one is the correct one to make things work. I'm going to price out both ways and see what comes up. Prob much simpler to keep the rear drums if possible. May not necessarily be any cheaper, but likely a much easier job. Last edited by vintage_mpg; 09-21-2021 at 09:05 AM. |
09-21-2021, 09:08 AM | #21 |
What about swapping out the complete rearend?
09-21-2021, 10:08 AM | #22 |
This thought crossed my mind....but I didn't want to get that involved. At least not yet!
The truck has a Spartan locker in the rear, so it's set up nicely right now. I'm just trying to squeeze in these large wheels and tires. But it's turning out to be quite the chore! The disc brake swap looks pretty involved as well, at least at first glance. Not sure I can do this without some coaching. The drum swap (to the smaller width shoe size) is probably the way I'll have to go. Again - that's without playing with the spacers or anything as of yet.... |
09-21-2021, 10:05 AM | #23 |
One thing to watch for is not all disk brake conversion kits include a parking/emergency brake feature.
09-21-2021, 10:18 AM | #24 |
Depending on the design of the backing plate you might need to pull the axles to change them out.
Maybe wheels that fit are the best option. |
09-21-2021, 01:05 PM | #25 | |
Here's why I'm pushing on this so hard: the PO purchased these custom wheels at tremendous cost based on his research with Squarebody Syndicate. According to him, the cost of the wheels and tires were right at $2200 for the set. He never got to use them, as he ran short on time trying to address this rear-wheel fitment issue...and when I picked up the truck, he just handed them to me, explaining what he had already run into. SO - different wheels may be the only answer - but gosh, I'd sure love to see these bad boys on the truck. I'm hoping that I can figure it out without throwing the bathwater out with the baby....or something like that! |
