Real Projects never die
Is it possible (modern transmission to older transfer case)
Has anyone ever done this? say mating up a 4l60e or similar modern overdrive transmission to a np205 tcase? maybe even a np208? The reason i ask is if i plan to use a 5.3/6.0 vortec, i figure i might as well use an overdrive transmission since i plan on running stock 3/4 or 1 ton axles, meaning ill have about a 3.73 or 4.11 gear, and im planning on having the truck be a highway trailer puller/daily driver. Any help or points in the right direction would be appreciated, thanks guys.
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
![]() Join Date: Feb 2000
Re: Is it possible (modern transmission to older transfer case)
Give Advance Adapters a call, they have lots of adapters and can surely help you out.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Professional Grade
32 spline NP208 or pass drop NP241 should bolt directly up to any 4l60e / 4l80e or either manual 5 speed manual available in the newer trucks without any adapters
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#4 | |
i like easy solutions to my ideas, gonna make funding it a heck of alot easier. ![]()
#5 | |
They come in 27 spline and 32 spline variants. A 4L60E will be 27 spline and a 4L80E will be 32 spline. You can mate a 4L60E to a 205 by cutting the output shaft of the trans or making a spacer and using a Th350/205 adapter. |
#6 | |
#7 | |
4L80E is the more modern version of the Th400, which was used in the 3/4t and 1t trucks. You could also bolt it to a late model NP205 with all stock GM parts. |
Grendal, I am going to use the advance adapters 4L80e to 27 spline np 205 adapter. Were can I find info. on using a 4l80E to a late model 205 using all gm parts. Thanks
