04-03-2023, 10:32 PM | #1 |
c10 66 breaklights
Hello
1966 c10 I'm looking for some assistance here. I cant seem to get my tail lights to work.. When I turn the headlights on both tail lights work, but the brake lights don't on either side. The drive side was working then stopped and now neither side work. Not sure what the issue could be, so if you have any suggestions please let me know. Thanks |
04-03-2023, 10:44 PM | #2 |
Re: c10 66 breaklights
Brake light circuit goes through the turn signal switch. Do either of the turn signals work in back?
04-03-2023, 10:49 PM | #3 | |
Thanks |
04-03-2023, 10:44 PM | #4 |
When things are intermittent with electrical, it's usually a connection issue (power OR ground).
When things are possessed by the Devil, it's usually a grounding issue (something is grounding through a different circuit).
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
04-04-2023, 09:03 AM | #5 |
Just asking.. Did you check the bulbs? Sometimes they can look good but not work.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
04-04-2023, 12:06 PM | #6 |
Per your post, it's just the brake lights that are not working. Helpful to have second person to assist you while you test.
1.Double check the bulbs, if you have known good spares, swap them out to verify it's NOT the bulbs 2.There is a brake light switch on the brake pedal lever (up under the dash) check to ensure it is engaging properly, there is adjustment built into that switch. If you have a known good spare, swap them out to verify the switch is not the issue 3.Per user Arne, verify that your turn signals are/are not working 4.Do a visual on the tail light housing, socket and wiring. You need a good ground at the housing for the taillights/brake lights to function properly. Sometimes it's a loose socket, wire or bad ground. Keep us posted once you have had a chance to check per the suggestions from members in this thread.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
04-04-2023, 10:37 PM | #7 | |
the 1st thing i did was replace the bulb... My dad was thinking it might be the brake light switch, i have to take a look this weekend. Thanks for the feedback. |
04-05-2023, 11:36 AM | #8 |
Great! keep at it and you'll get it figured out. The members in this forum are a great resource for help along the way.
04-06-2023, 05:06 PM | #9 |
Moderator
I've posted this before, but here's how I got my brake lights to work properly:
- removed the lenses, removed the buckets - added a ground from bucket to bed - added a ground from bed to frame at back - added a ground from bed to frame at front of bed - added a ground from back of cab to frame - added a ground from front of bed to cab Brake lights work perfectly now. Before, one worked dimly, and one only had "lights on", no brake illumination. |
04-08-2023, 01:56 AM | #10 | |
Thanks |
04-08-2023, 10:41 AM | #11 |
Yes, a dirty ground, bad ground can result in having running lights (and most likely dim at that) and no brake lights. The bulb socket grounds itself to the housing which then has a ground wire to frame or body or both. It's important to make sure the bulb socket is tight and secure in the housing, if it's loose (turns freely), it will result in intermittent issues as well. Be sure to check all these things on both tail lights. Clean your ground surfaces really well if they are already in place.
04-14-2023, 04:02 AM | #12 |
Thank for the feedback. Wont get a chance till next week, but ill keep you guys updated.
05-07-2023, 03:16 PM | #13 |
Ok so I finally got time to mess with my brake lights. It looks like the issue is with the Taillight Pigtail connector. I'm now just going to upgrade to LED tail lights. My question is what led tail lights do you guys recommend?
Also I noticed I have 3 wires running to the brake light but all the LED lights only have 2... Thanks Last edited by networx2002; 05-07-2023 at 08:19 PM. |
05-08-2023, 03:42 AM | #14 |
I went led with mine.
United pacific is what i used. There is 3 wires coming from module but still has a 1157 male connector to fit the oe socket. Since mine never came with the original wiring i did my own wires and used 3 pin deutch connector and did earth directly to frame . Pic is brake lights on. Nice and bright. Cheers. Adriaan. |
05-08-2023, 11:10 AM | #15 |
I used these. (Sorry it's just the package) Simply plug in place of the old ones. No wiring, no mods.
05-08-2023, 12:24 PM | #16 |
A couple notes: Make sure you get red LED bulbs, not white. (White through a red lens will be rather dim.) And note that you may need to replace the signal flasher relay to an electronic unit if the signals flash very fast.
Tags |
1966 c10, brake lights |
