Old 05-01-2003, 03:12 AM   #1
jose
jose's Avatar
WTB two 4x4 brake lines
Want to buy two top brake lines from brake proportioned valve to frame has to be from 71/72 4x4 disk brake set-up .
jose6772@mtangel.net
68 GMC 4x4 SWB
jose6772@yahoo.com
jose is offline   Reply With Quote
Old 05-01-2003, 10:23 AM   #2
ljbear
ljbear's Avatar
Jose,
I have a set that are in good shape from a 71 4x4 with discs. I'm in Northern Cal so shipping won't be too bad. Do you want the the small set from the master cylinder to proportioning vavle as well? PM an offer if interested and I can get a picture sent also if needed.
Larry
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 05-01-2003, 07:03 PM   #3
Blue_71
Bloo
Blue_71's Avatar
if he doesnt need the short set from the master cylinder to proportioning valve i'll take them if it's for a master cylinder with the front brake pot in the back
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 05-05-2003, 01:51 PM   #4
ljbear
ljbear's Avatar
Blue_71,
I'm not sure if I follow what you're saying. The front brakes on mine run off the front pot and are the smaller of the two lines, with the larger line in the back running the rear brakes. The smaller line enters the proprtioning valve on top and exits the proportioning valve on the bottom, while the larger line enters on top and exits to the rear of the valve. Here's a picture that may clear up what I have.
Larry
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
Old 05-05-2003, 06:13 PM   #5
Blue_71
Bloo
Blue_71's Avatar
you got a pic that shows the master cylinder? im starting to think theres two different 71 master cylinders... my 2wd is like the one in the picture, but the 4x4 has a bigger pot in the back, which hooks to the front brakes, and a smaller line coming from it, while the front pot is smaller, with a larger line, and hooks to the back brakes
btw-- your brake warning light is unhooked
Old 05-05-2003, 06:47 PM   #6
ljbear
ljbear's Avatar
I wish the brake light wire was all that was unhooked. Here's a picture of the master cylinder, proportioning valve, and booster. This is the only way I've seen it.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
Old 05-05-2003, 07:03 PM   #7
Blue_71
Bloo
Blue_71's Avatar
wonder if its a 1/2 ton-3/4 ton difference? thats identical to the set up on my 71 1/2 ton 2wd, even though it has manual brakes, but ive got a different set up on my 3/4 ton 4x4....
1989 Chevy K2500
Old 05-05-2003, 07:13 PM   #8
ljbear
ljbear's Avatar
That sounds possible. Looks like the master cylinders have different part numbers in a couple of sources I checked.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
