02-23-2011, 09:41 PM | #1 |
Alternator mounting with fuelie heads
Hello guys,
I am unsure what to do here, any information would be great. I have a 70 CST 1/2 ton with a 350, I pulled the motor and was going to rebuild it. A friend of mine has a machine shop and sold me a 350 with 327 heads he just finished building, and the customer would not pay for. So I got the motor cheaper then rebuilding my motor, just had to pay for his machine work and labor. I have the motor in place and the power steering pump is on the motor no problem. I need to mount the alternator but I have no accessory holes on the heads. My buddy called them fuelie heads, I am sure there must be some type of bracket to mount the alternator. Or do I need to fab something up? Sorry I forgot to tell you that the motor has a long water pump. I have the power steering pump mounted off the block and the water pump. No more hole left on the drivers side so the way I see it the alternator will have to go on the pass. side of motor. It is a a/c truck also, but the compressor is bad so I will cross that bridge when I get to it, if I hook up the a/c. I am close to having her running again, any and all ideas welcomed. Thanks for any help! |
02-23-2011, 10:12 PM | #2 |
Active Member
Re: Alternator mounting with fuelie heads
You should be able to buy an aftermarket bracket - the issue might be they are all designed for a short water pump when we look at the passenger side mounts.
You can also look at a low mount kit for the passenger side which might get you to where you need to go - might have to go billet alum
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
02-23-2011, 10:20 PM | #3 | |
02-23-2011, 10:25 PM | #4 |
Check out this website. Stuff is made in Kansas real good quality for a fair price. I just bought a set for my BBC project. http://www.alangrovecomponents.com/S..._Long_Pump.htm
02-23-2011, 10:35 PM | #5 | |
02-23-2011, 11:14 PM | #6 |
You can buy a aftermarket bracket for about $20 if your running headers that will keep it on the drvs side.If your running the ram horns manifold then the bolt hole is on the end of the manifold for the alt. to mount allso on the drvs side,I am running 327 with fuelie,power pak, camel hump, 202 heads and my alt is on the drvs side I am running it with headers.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
02-23-2011, 11:49 PM | #7 | |
02-24-2011, 12:46 AM | #8 |
You use a long bracket that goes to the top water pump bolt or to the intake that has a long slot on it for adj..The bottom one is sort of a Y shape I am not worth a dam at posting pics but do search and I think you'll find a pic
10-21-2020, 11:22 PM | #9 |
Where may i buy a bracket like this, for a set of 462's and keep alt on driver side. Also do you know where i may find an a/c bracket for passenger side?
Mick 1972 C20 Deluxe MADE IN the U.S.A. |
10-22-2020, 08:27 AM | #10 |
Look in the for sale section for a/c brackets ,allso sumitt has the alt. brackets
02-24-2011, 07:54 AM | #11 |
Curious as to if the machine shop can drill and tap a hole in these heads? Has that been asked? If so that would have to be much cheaper and less headaches than buying new brackets.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
02-24-2011, 08:19 AM | #12 |
I am going to suggest a whole different route. Take those heads off and sell them to a muscle car collector. Go buy some brand new Vortec heads for less than what the right buyer will pay for high quality rebuilt fuelie or double-hump heads. You get 1) Hardened valve seats 2)holes for acessories 3)better combustion-more power and efficiency 4) valve covers that seal. Same exhaust, you do have to get a special intake-or redrill the Vortec heads for early intake pattern. Just a thought.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
02-24-2011, 08:32 AM | #13 |
I have the same setup your working with but on my 383 stroker, I have a short water pump with fuelie heads, I made my own brackets I will get a set of pictures to show later today.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
02-24-2011, 01:25 PM | #14 |
I have a 327 with a long water pump and no accessory holes in the head. I am running the power steering pump on the driver's side and using Alan Grove brackets to run the alternator on the passenger side.
It is part number 215R - Alt. and 215RO - Alt. on the link below. http://www.alangrovecomponents.com/S..._Long_Pump.htm I got them a little cheaper through www.amazon.com. Here is the only picture I have right now:
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need Last edited by brn agn; 02-24-2011 at 01:30 PM. |
