01-30-2021, 10:44 AM | #1 |
Radiator question
Im.looking for a radiator for my 70 C10 truck. The one that came out was a 4 core but im not finding much online for a replacement. All I find in 2 and 3 row. Or they have transmission cooler ports. I guess I could just plug the ports. Thoughts? I'm getting closer to firing the engine and this is one of the last things I need.
01-30-2021, 11:19 AM | #2 |
Re: Radiator question
I don't have any personal experience with this product, but NPD has a 4 row radiator listed on their site.
https://www.npdlink.com/product/radi...1969&year=1969 |
01-30-2021, 11:28 AM | #3 | |
01-30-2021, 11:33 AM | #4 |
Most AL radiators you find will only be 2 or 3 rows cores. They are more efficient than brass/copper radiators hence the need for less rows. The rows also also a bit large in the AL radiators as compared to the brass/copper type.
01-30-2021, 12:08 PM | #5 |
A lot of guys are using a Champion CC369 and they are on sale for $214.98 + .
the CC369-M comes without the auto trans line ports - https://www.championradiators.com/product/CC369-M https://www.championradiators.com/pr...iABEgLGcfD_BwE
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
01-30-2021, 08:00 PM | #6 | |
01-30-2021, 11:37 AM | #7 |
Check out RnD Fabrication, I'm running 3 of them, one is 10 years old.
http://www.rndfabrication.com/CrossflowRadiators.html
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
01-30-2021, 12:02 PM | #8 | |
01-30-2021, 12:41 PM | #9 |
In a covid environment I don't know. Call and ask, very friendly people. The owner, Sparky, usually answers the phone.
01-30-2021, 02:39 PM | #10 |
Old member
Here is a thread I did on mine a few years ago 2015 when I bought the aluminum one for the 71. I have one in the ramp truck, 64 SS Impala and had one in my 56. Not one problem out of any of them. The 71 with LS 6.0 never cuts the fans on unless I'm sitting still for a period of time. No plastic and all tig welded.
http://67-72chevytrucks.com/vboard/s...=681849&page=2
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-30-2021, 03:17 PM | #11 |
20' Daredevil (Ret)
My K20 has an all-metal 4-row I bought many years ago.
If / when it needs replacing, I'll take a good long look at 2-row radiators. Food for thought:
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
01-30-2021, 04:38 PM | #12 |
I found the 2 row mentioned above , Its currently out of stock . $247.00
http://www.speedcooling.com/1967_197..._Radiator.html
01-30-2021, 05:44 PM | #13 |
That's the one I have, Grumpy old man.
01-30-2021, 06:08 PM | #14 |
How did it work for you ? Stock fan shroud ? radiator mounts?
01-30-2021, 08:21 PM | #15 |
Yes it fit fine. The shape where it fits into the support bracket is a little weird, but it works fine. I am using the original shroud that I recently restored with new upper mount ears because they were broken off; I used the super glue and baking soda method you recommended. There is about a 1/4 inch gap along the top of the radiator to shroud and I don't know if that would be different with the stock radiator. The gap has not bothered me. I sold that original 4-row radiator to another board member a few years ago, and at the time I was using the old radiator the shroud had broken ears so I don't know how it would have fit at that time. My new Engineered Cooling Products radiator is now about 4 years old.
01-31-2021, 12:02 AM | #16 |
Cold Case aluminum radiator. Stamped tanks and it looks just like the original. Good quality and fits like it should in the factory big block mounts due to size
1971 Custom/10 - 350/3 speed, Orange/White roof |
01-31-2021, 06:01 AM | #17 |
I was wondering about cold case. I see it is a two row but they say they cool better than an old 4 row. Anyone else using one?
01-31-2021, 07:18 AM | #18 |
Thanks for all the replies. I decided to go with a cold case. All the reviews seemed positive pluse my summit store has it in stock 100 miles away. Should get it very quick. Thanks again!
01-31-2021, 07:41 AM | #19 |
I didn’t See the post before your purchase, I have the Cold Case and I have a BB, in my Gmc, plus I live in Florida, very pleased with it so far, I’m still running the factory fan shroud as well,
01-31-2021, 08:48 AM | #20 |
Awesome! Good to know. I was wondering if I should run a shroud or not. My dad daily drove it for 30 years and it never had a shroud. I guess adding one could only help the cooling abilities.
01-31-2021, 08:59 AM | #21 | |
Posted via Mobile Device |
01-31-2021, 11:29 AM | #22 | |
20' Daredevil (Ret)
And as noted above, a 6- or 7-blade fan on a heavy duty thermal clutch. If you think I hate overheating..... you're right!
01-31-2021, 11:49 AM | #23 |
I have a 6 blade fan with the Hayden 2705 clutch with a shroud , I think I'm going to order the champion CC369-M and see how that set up works .
01-31-2021, 10:15 AM | #24 |
Another vote for the Champion CC369. It always runs cool. I had to use the heavy duty (wider) rubber mounting pads for the thicker core. I use a standard 4WD shroud since my SBC is in the back (4WD) position. Sounds like the Cold Case is a quality unit too.
For the fan I have a Derale 17118 6-blade 18" rigid fan and a Hayden 2705 thermal fan clutch w/clockwise rotation. This set up works great and fits nicely inside the shroud if you're not going with electric fans.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. Last edited by tim_mc; 01-31-2021 at 10:24 AM. |
