v8 sm465 bellhousing,crossmember, and clutch linkage
I am looking for:
v8 sm465 bellhousing, crossmember, and clutch linkage I know its alot. any help would be appreciated! |
![]() Join Date: Jun 2009
Re: v8 sm465 bellhousing,crossmember, and clutch linkage
I have a
Complete sm465. Would you be interested in the whole thing?
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 |
Hi
Does the bellhousing have the place for the clutch pivot ball on the driver side, and the starter provision on the passenger side? Also, what is the depth of the bellhousingand the width of the center shaft hole? What are you asking for it? Thank you. Do you have a crossmember and clutch linkage? |
What year truck are you putting it in? I have some clutch linkage and a bell for a 73-84, need to dig, may have crossmember too.
Also same for a 64-66 |
Man, i need to be more specific... sorry... It is a 68 c10 with a sm465 trans with a inline six trans crossmember. Im told its different from the v8 crossmember and i need a sm465 transmission crossmember for the v8
I’m by no means an expert but I used my stock inline 6 trans crossmember with a 350 swap. It did put the motor in the rear (4x4) position but it worked fine.
![]() Join Date: Nov 2015
I may have some of the pieces you need, However the crossmember I have was modified for use with mid length headers, or Ls exhaust manifolds, But if you can’t find another one, perhaps it would help you out.
The bell housing has some damage that did not affect the starter mount, but again not perfect anymore. I have the linkage, z bar, frame bracket, spring, etc. I’m not an expert on what fits what, or can interchange, just trying to help if I can. The parts came off a 72 C10 with a 350 and a sm465 transmission. The transmission , clutch disk, and pressure plate have been sold, but I have the rest of the parts. Shipping from MN. May not be cost effective. Not sure what it’s worth, but $ is not my real concern, seeing the parts going to good use, and helping a member out is more important.
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
