My 72 didn't come with a tach in it, but will the wiring be there for it? I am going to replace the bezel and was just curious if the wiring was done for a tach on all the 67-72's
------------------ 72 C/10 LWB 2wd 250 inline 6, 3 speed column shift. Soon to have a total facelift.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
![]() Join Date: Dec 1999
No its only in the tach trucks,but its a simple harness to make only a couple wires,one to fuse box other to distributor
HEI is to dist.points to coil.
If adding to truck in your signature and you have a 6cyl and using factory take make sure its a 6cyl one not a V8 ,most after market takes you can use either way,by the flip of a switch)
A factory tach can be recalibrated with a small screw driver, for use on a 6 or 8 cylinder.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
I will be swapping the inline 6 out in a couple months for a 350. I think i just might have to check into what the wiring harness will cost. Thanks guys
Wiring harness costs 18.95 from GMCPauls. I also opted just to buy the harness rather than make one saves on asprin. blaze
Strongman Garage
![]() Join Date: Apr 2000
uhhhh its one wire to fuse panel, two terminals on both ends and one to distrib.. if you need asprin for that.....
------------------ My Truck pictures www.xframeimpala.com 68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET" 56 big window short stepside 235 dual 1 brls 64ImpalaSS 327 70 C10 LWB fleetside custom/10 350/TH350 IM me on aol SN= SHAGROLET
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
Ok, I found a pic of it at GMC Pauls website. Good price if you live in the USA, but $18.95 in Canadian, once the shipping and all is included, it's over $45!!
![]() Man you guys in the States got it made when it comes to buying parts. I see cab corners are like $14 at GMC Pauls, we have to pay in the upwards of $40 CDN here. I think i should move to the USA just so I can finish my truck ![]() ------------------ 72 C/10 LWB 2wd 250 inline 6, 3 speed column shift. Soon to have a total facelift.
Any 3 3/4" dia tach can be used. I have used 78-86 Camaro and Sun Super II tachs.
To wire a tach, (-)black to back of dash (screw)for ground, (+)red to ignition switch-on, or to fuse panel unfused (use a inline 10amp fuse), green to coil or HEI (tach). The Camaro tach fits nicely into the dash metal case, the Sun requires alot more work. ------------------ 72 Cheyenne Super, Fleetside, Shortbed, Original Owner
72 Cheyenne Super, Fleetside, Shortbed, Original Owner, Special Ordered 350ci/340hp, Auto Trans, 3:70 Posi, Tow Package Northern Calif |
