09-01-2012, 04:51 PM | #1 |
JD2 Tube Bender Hydraulic Conversion
Bought an air over hydraulic ram a while ago at HF with the intention of doing this. Finally took some time off other projects to get it done.
Manual tube bender (JD2 Model 32) Decided to use existing parts as much as possible without making irreversible changes. This manual lever arm became the host for the ram. Here it is in the manual config (I ended up flipping it over later) Ring templates/guides for plasma: Cylinder support: The cylinder assembly slides on over the existing lever arm and bolts on with 3 1/2" bolts. Holes are evenly spaced so two positions are available. I plan to add a back-bone to the tube/ram support for increased capacity. With spacers installed: Template for the ram attachment bracket: Installed and working |
09-04-2012, 12:04 AM | #2 |
I dun gradjiated collij!!!
Re: JD2 Tube Bender Hydraulic Conversion
That is slick!
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! |
09-06-2012, 12:43 AM | #3 |
Works great. Guess you and I are the only ones who understand the what it does
09-08-2012, 10:52 PM | #4 |
Wish I had one... would save a fortune in mandrel bends and pre-bent stuff for the Chevelle and future projects...
09-06-2012, 01:47 AM | #5 |
VA72C10
That's VERY cool! Better than what most exhaust shops have....that's for sure
Looking for a 67-72 swb or blazer project in or around VA. |
09-06-2012, 01:48 AM | #6 |
VA72C10
Building a roll cage for the minx?
09-06-2012, 08:18 PM | #7 |
No cage for the Minx just yet but I did use it (manually) for the A-arms, engine mounts, and front frame cross-brace. My wife's FJ40 will see the first benefit from this; cage, bumper, sliders, maybe tube fenders, etc.
Posted via Mobile Device Posted via Mobile Device |
09-06-2012, 08:48 PM | #8 |
Newbee
I keep threatening to do that to mine...
I keep forgetting how much it hurts, until I get done with another cage. I do have a 5' handle though |
09-09-2012, 01:37 PM | #9 |
Wish it could do exhaust!
10-13-2013, 07:04 PM | #10 |
My Jd32 arrived last Friday, ordered the same ram from HF and its here. Have two sticks of 1.5" .120 DOM ready for bending.
Your write up on the bender is going to have a major impact on my build. Thanks for taking the time on the info. |
08-29-2015, 03:14 PM | #11 |
you might be able if you fill the tube with ice
they make trumpets and trombones by filling the pipes with water and freese them before bending , after bendeing they just les the ice taw out and pour it out of the pipe
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
08-30-2015, 04:55 PM | #12 | |
I bent thin-walled aluminum in this bender by annealing it and packing it with sand. Problem with ice is finding a big enough freezer to put the pipe in.. |
10-23-2013, 10:22 AM | #13 |
Hey Bomp, just saw this. Glad to help bud
10-23-2013, 11:09 AM | #14 |
I've dreamed of doing something like this. Glad to see someone has the time to make the dream come true and work out the bugs before I get to it. :-)
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
10-23-2013, 09:00 PM | #15 |
One of the best things about this conversion (besides the obvious advantage of being hydraulic) is that it is now mobile and does not have to be bolted down to use. The stand I have it on now has 6 casters
12-08-2013, 10:05 PM | #16 |
1 thing at a time is progress.
Very well done. Maybe I can get this setup someday. Thanks for posting.
Alan
Philippians 2:14-16 |
12-09-2013, 03:13 PM | #17 |
Thanks Alan. I saw that Bomp has his converted and twisting tubes up! I'm sure you guys will improve on it
12-21-2013, 04:13 PM | #18 |
Just got the manual version of this at work, it sure is a lot of fun to play with. We are running it in the horizontal orientation. Added a hitch receiver style mount that slides into a slot in the top of our welding table.
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
01-28-2015, 03:34 AM | #19 |
Hey Mike... Guess what I'm getting with this next bonus... Gonna do the hydro mod as well (shamelessly ripping off your ideas).
I just got done doing an HF bead roller with winch motor and foot control. Works like a charm.
01-29-2015, 02:49 AM | #20 |
Sooooo........ did anybody post a how too on this one somewhere?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
01-30-2015, 12:15 AM | #21 | |
I need to mod my bead roller. Where's the build? |
01-28-2015, 04:56 PM | #22 |
MOVE OVER
lots of talent here.. wish I could do something like this..
No matter where you are..... There you are... Buckaroo Banzi |
02-04-2015, 03:47 AM | #23 |
I'll get it posted up ASAP...
02-04-2015, 04:41 AM | #24 |
02-05-2015, 04:20 AM | #25 |
Thanks for the link!
