03-20-2021, 04:16 PM | #1 |
Door Hinge: Friction Pad / Check Link Solution?
I have questions below
I have been searching the Forum and found some old threads on this subject. If there was some new threads I missed them So I thought I would start this one. If you know of one please add the link to help others in the future #1 =There is this Reproduction Kit in the link below. Link: https://www.classicparts.com/1967-72...ctinfo/18-432/ #2 NOS friction pads = hard to find Borrowed picture from member that I have purchased many parts from. Thanks Question #1 - Is the Kit a decent replacement? Question #2 - Has anyone found a comparably material to make these out of? I prefer not to mess with asbestous One member on here used Nyltron. His update was: {The Nylatron sheet that I used in the hinges for friction pads didn’t perform as good as I wanted them to.} Question #3: What have you used as a successful replacement if they are missing ? Thanks .
03-20-2021, 04:24 PM | #2 |
Who Changed This?
Re: Door Hinge: Friction Pad / Check Link Solution?
I forget where I bought the kit, but I have yet to get the pin out of the hinge. Guess I'll spray some more penetrating oil on it and have at it again. They are the nylon(?) pads. Only the driver's door needs them.
03-20-2021, 04:31 PM | #3 | |
From the picture ,I thought they might be nylon. If so I can make some/ If they work okay? About that pin I have had some that come out okay and one that is still soaking .
03-20-2021, 06:09 PM | #4 |
Who Changed This?
So, I went out to take another try at the pin, and the face of my ball peen hammer is so beat up that I got a slice from a section that is peeling off. Time for a new hammer, I guess. I've probably had it over 50 years. I said the heck with it and went back in the house.
03-20-2021, 06:40 PM | #5 | |
That pin that holds the check link arms is 3/16. I read where another member replaced these with 1/4 " after he got them out. .
03-20-2021, 07:03 PM | #6 | |
20' Daredevil (Ret)
http://67-72chevytrucks.com/vboard/s...=318544&page=5
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
03-20-2021, 06:15 PM | #7 | |
20' Daredevil (Ret)
The hinge has a 1/4" diameter hole top & bottom, but the roll pin is 3/16". If you try to drive the pin out with a 1/4" drift, you'll be stopped by the 3/16" section at the center of the hinge. A smaller drift, 3/16" or less, will drive the pin out. HTH, good luck!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 03-20-2021 at 06:25 PM. |
03-20-2021, 09:08 PM | #8 | |
Who Changed This?
03-20-2021, 06:03 PM | #9 |
20' Daredevil (Ret)
From a 9 year old thread:
03-20-2021, 06:36 PM | #10 |
This is an option. I just wonder how a person could get it to size, Without breathing or dealing with the asbestos or nasty stuff. .
03-21-2021, 02:04 AM | #11 |
One doesn't have to remove the pin or the link to replace the pads.
I have attempted to get the pin out many times with no luck. If you pull the hinge pin you can drive the link out between the pads. Typically the hinge pin has to come out to replace the bushings anyway. Sometimes they come apart easy, sometimes hard. One picture of a pin I had to drill out. If the pin is rusted in soild you can bend the hinge ears if you use a press. Sometimes an air hammer can be used effectively. I like to powder coat them when I am done. Rick Last edited by Accelo; 03-21-2021 at 03:30 AM. |
04-17-2021, 12:08 AM | #12 |
Okay
Here is what I have found I purchased some big Sheet material and machined it to size I still have to machine the notches in the ends It has Copper emebeded in it. .
04-17-2021, 12:39 AM | #13 | |
20' Daredevil (Ret)
04-17-2021, 06:22 AM | #14 | |
Time will tell .
