Leaking proportioning valve
My proportioning valve has developed a leak around the little rubber boot that covers the valve on the end of the prop. cylinder block.
This came about after I changed the front brake pads. Is this something I can fix with a new O ring or something? I don't know too much about how these things work. |
![]() Join Date: Jul 2016
Re: Leaking proportioning valve
Aftermarket brass? They always leak
#4 | |
Take it apart and Figure out whats wrong with it, there must be a burr or some defect causing them to leak. |
Old member
Look for one that doesn't have the button. Good insurance.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#6 | |
Bad luck is that it'll have to wait as they are closed due to the virus thing. |
'67 GMC 2500, 292, 4spd, AC Last edited by RichardJ; 04-08-2020 at 11:35 AM. |
Old member
Do yourself a favor and get one without the rubber boot. I had one and it blew out coming up to a stop sign with no warning!
