Old 12-20-2009, 08:27 PM   #1
bestchevyfan
Drive shaft and trailing arm question
First of all, how do you replace the bushings on the trailing arms? They are out of the truck. Secondly, how do you take the drive shaft apart at the carrier bearing?
bestchevyfan is offline   Reply With Quote
Old 12-20-2009, 10:55 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Drive shaft and trailing arm question
I used a ball joint press to change out the bushings and for the drive shaft remove the ujoint and remove the bolt that's in the center of the shaft.
hayhauler71 is offline   Reply With Quote
Old 12-21-2009, 08:40 PM   #3
chris91
I used a torch to remove my trailing arm bushings. Which carrier bearing do you have?
chris91 is offline   Reply With Quote
Old 12-21-2009, 11:42 PM   #4
rick0312
rick0312's Avatar
first off if you live near an autozone take advandage of their tool lending program. Follow this link for overhaul of driveshaft. http://67-72chevytrucks.com/vboard/s...d.php?t=171772 I don't know why the pictures don't show up anymore, but at least you can read through it....shame though because it was a very informative write up with great photos on driveshaft overhaul...maybe something the admins can fix......Rick
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 12-22-2009, 11:55 AM   #5
kevmic28
kevmic28's Avatar
Wish it had pic too. I need to replace my carrier bearing. Any one have a part number for the carrier bearing for a 2 piece drive shaft?
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
driveshaft, trailing arms
