09-25-2022, 11:47 PM | #1 |
Full time 4wd hub refresh
I promise I searched here before posting and came up mostly empty handed. Anyways I have a 78 k10 full time 4wd and I'd like to put new wheel bearings in it. I've only ever had 2wd squares and never really messed with older 4x4 hubs. I can't seem to find any information on the earlier hubs, everything I find is for the 80s style bolt on full time hubs. So I'm looking for any torque specs or general pointers, or if you're kind enough to do and general write up I would greatly appreciate it. Thank you for any information
1970 Chevrolet custom camper 20 2000 F@$d F250 Powerjoke "And i still like bologna on white bread now and then" -Alan Jackson |
09-26-2022, 05:52 AM | #2 |
Re: Full time 4wd hub refresh
Primarily because in the everyone converted their full time to part time with locking hubs. Much easier on equipment when driving on the road.
I can usually find a service manual on evilflay. A bit of an investment but well worth it.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
09-26-2022, 06:41 AM | #3 |
A lot of the old manuals had write ups on how to do it. It's not much different than the 2wd bearings. You do have to buy the spindle nut wrench. I have been running full time 4x4 for 30 years and wouldn't have anything else. I used to chew up wheel bearings after water crossings so I try not to anymore.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
09-26-2022, 12:28 PM | #4 |
Here is a link to the 1978 Service Manual in PDF format http://www.73-87chevytrucks.com/tech...ice_Manual.pdf
Page 288 in the pdf outlines the wheel bearing adjustment with torque specs and the following pages go through the hub removal/replacement process. If you're in that far its always a good idea to replace spindle seals and the bearing (or pack the spindle bearing if its in good condition) especially in a full-time four wheel drive application. If you have full time four wheel drive you have a chrome dust cap with a drive flange inside the wheel hub instead of a lockout hub or the automatic locking hubs from the 80's. However, wheel bearing replacement is the same process regardless of what drive flange/locking hub you have.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
09-26-2022, 01:00 PM | #5 |
Thank you all very much for input and help, I truly appreciate it
