Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 01-01-2004, 02:41 PM   #1
krue
Designated A-hole!
krue's Avatar
Bowtiebandits window regulator swap instructions.
Door vent window
1. Lower the window all the way
2. remove the door trim panel
3. remove the door lock knob
4. remove the screws which attach the vent window lower
assembly to the door panel
5. loosen the inner and outer panel screws which are accessable
through the hole to the rear of the lower vent pivot
6. slide the main glass to the rear, away from the vent window
7. turn the complete assembly 90 degrees and guide it up and
out of the door
8. installation is the reverse of the removal
Door window glass and regulator
1. lower the glass completely, remove the window regulator
handle and the door lock knob
2. remove the door armrest and trim panel
3. remove the door vent window (above)
4. slide the main window glass forward until the front roller
is in alignment with the notch in the sash channel. Disengage
the roller
5. push the window forward and tilt the front edge up until the
rear roller is disengaged
6. return the window glass to the level positionand withdraw it
from the door
7. if necessary, remove the mounting screws and withdraw the
regulator assemblythrough the lower opening in the door
8. prior to installation lube the regulator mechanism with chassis
grease
9. installation is the reverse of removal
Hope this helps.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline
Old 08-29-2004, 10:44 AM   #2
71-longbed
Its Magically Delicious
71-longbed's Avatar
ok .. my regulator is stuck in the up position ... this is what the service manual says ..... i hope i can manage it the way the manual states
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline
Old 12-02-2004, 12:43 PM   #3
crm318
Alright Alright Alright
crm318's Avatar
how do i remove the vent window?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline
Old 05-02-2005, 04:06 PM   #4
71-longbed
71-longbed's Avatar
what would you suggest if the window is frozen in the up position ???
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 05-26-2005, 10:17 PM   #5
krue
Designated A-hole!
krue's Avatar
Vice grips or a small pipe wrench.
www.daveramsey.com
krue is offline
Old 12-06-2004, 11:32 PM   #6
krue
Designated A-hole!
krue's Avatar
1. Shows where to remove armrest and handles.
2. Door without armrest and handles, prior to removing panel.
3. Shows the door panel gone, and where the vent window and regulator screws are.
4. The rest of the screws to remove vent window.
www.daveramsey.com
krue is offline
Closed Thread
