Old 02-20-2011, 05:34 PM   #1
charx2
charx2's Avatar
How do I tell if I have drop spindles?
I'm trying to determine if PO put spindles on, how can I tell? I can't take the wheel off because it's on bags and my tanks aren't on ATM and my jack won't go low enough to lift it up. I did measure and with 225/70/15, the middle of the wheel bearing is at 14". Trying to order some stuff but don't want to order those if I already have them. Can anyone measure for me?
My 67 c10 Thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=409192
charx2 is offline   Reply With Quote
Old 02-20-2011, 06:11 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: How do I tell if I have drop spindles?
Can you cut the wheels enough to look at the back side. Take a pic and let us look. If the axle spud is noticeably off center then its a drop spindle.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-20-2011, 07:04 PM   #3
Shane
Shane's Avatar
actually, a drop spindle will have the spud closer to the center whereas a stock spindle will have the spud towards the bottom of the spindle casting ...
drop spindle ...
stock spindle ...
Shane is offline   Reply With Quote
Old 02-20-2011, 10:22 PM   #4
charx2
charx2's Avatar
[IMG][/IMG]
My 67 c10 Thread.
Old 02-20-2011, 10:25 PM   #5
charx2
charx2's Avatar
Hope these help, thanks guys your help is very much appreciated.
My 67 c10 Thread.
Old 02-20-2011, 10:28 PM   #6
bagged74
its just $$$$$
bagged74's Avatar
those are drop spindles
bagged74 is offline   Reply With Quote
Old 02-20-2011, 10:49 PM   #7
charx2
charx2's Avatar
Really? How can you tell? I was pretty sure they were stock after seeing Shane pics.
My 67 c10 Thread.
Old 02-20-2011, 11:21 PM   #8
70jnktrk
70jnktrk's Avatar
check out the supplied photos
70jnktrk is offline   Reply With Quote
Old 03-03-2011, 07:39 AM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you look closely you can sell the Belltech logo cast into the backside of them.
As to telling the difference between stock and dropped, to me, it's easier to look at the steering arm. If it's straight out, it's stock, dog leg shaped, it's a drop spindle..
Here are pictures I took of a truck I dropped last year.
Stock spindle, notice the straight out steering arm...
Drop spindle, notice the dog leg downward slant of the steering arm...
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-20-2011, 11:39 PM   #10
charx2
charx2's Avatar
Well damn, that saves me a few hundred buckaroos!! I'm still surprised though, it's the first thing I've wanted to do that seems to be done correctly! Well, now to decide on which 4 link! Thanks again guys.
My 67 c10 Thread.
Old 03-02-2011, 09:11 PM   #11
maxxxy
maxxxy's Avatar
Could any of you veryify that these are NOT drop spindles?
I'm looking for ways to go lower in the front on my bagged 81 truck, but I don't want Z it or buy a dropmember so hopefully these are NOT drop spindles.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 03-02-2011, 09:39 PM   #12
bagged74
its just $$$$$
bagged74's Avatar
those are stock spindles. notice how the spindle shaft itself is just barely above the lower ball joint. Drop spindles have the shaft higher up on the spindle itself....hope that makes sense
