Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 09-25-2010, 04:44 PM   #1
67Slider
67Slider's Avatar
69 Camaro Gas Tank Install
I have been wanting to install a behind the license plate tank since I bought my truck. I took this as an opportunity to help anyone else who may want to go this route.
Mods - If this need to go someplace else - no problem with me.
Here goes.......
I bought a 69 Camaro gas tank(18 Gallon), sending unit, straps and anti, squeak kit from a company off of E-bay by ther name of Tamraz for 194.00 shipped. Don't order off ebay, just call the company tell them about the forum and this install and they "may" cut you a deal. Don' bother with the 69 Camaro gas tank straps. It's easier to fabricate your own than use theirs. See if they will swap out the straps for the anti-squeak kit.
Their # is 1800-442-4601
Here is a list of other items needed:
Flip down license plate holder - 10.00 U-pull
6 ft metal tubing 2"x3" and 8' of 1"x 1/8 strapping - $30 at steel distibutor
10' 3/8 tubing, 4' rubber fuel line, locking gas cap, union for tubing - 32.00 @ Autozone
Misc hardware to mount tank to frame and fuel line - $10 at hardware store
Total about 276.00
[IMG][/IMG]
I started by mocking up the tank to the frame to see how much of a spacer I would need with my bumper
[IMG][/IMG]
[IMG][/IMG]
Once I got the right height I took off the license plate bracket and cut out a square with the cut off wheel, drilled a couple of holes in the bracket and mounted the flip down holder.
[IMG][/IMG]
I cut the 2x3 square, drilled the holes and mounted it to the frame. After that I cut the 1x1/8 and bent them into the shape of the tank, drilled holes and did a test fit.
[IMG][/IMG]
Put everything in place and slid the anti squeak pieces in, tightened it all down.
[IMG][/IMG]
Took out the old tank and fuel lines and pre-bent the new lines to match the old one.
[IMG][/IMG]
Then installed the front portion using the old clips. Installed the back portion with some new clips and hoses.
[IMG][/IMG]
[IMG][/IMG]
I still need to hang the exhaust so that it doesn't hit the tank and smooth the old gas neck hole but that will be another day.
Here is the finished product.
[IMG][/IMG]
I have to say thanks to Bad70sbchevy, without his pics and info none of this would have gotten done. This is truly his build I just detailed it a bit more.
I took a bunch more pics and they are in my gallery if you want to check them out.
Matt
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 09-25-2010, 05:54 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: 69 Camaro Gas Tank Install
so thats the original filler area? Does it leak or anything?
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 09-25-2010, 06:09 PM   #3
LONGHAIR
A whole lot of '60s to mid '70s GM cars were like that.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline
Old 10-05-2010, 05:28 PM   #4
67Slider
67Slider's Avatar
Mine is a stepside. Works fine.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 01-02-2011, 07:18 PM   #5
67Slider
67Slider's Avatar
Here are a couple of pics with the bed bolted in. No clearance issues.
[IMG][/IMG]
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 01-02-2011, 07:28 PM   #6
sjarrett71
sjarrett71's Avatar
What is the capacity of the camaro tank?
-Scott-
sjarrett71 is offline
Old 01-02-2011, 07:30 PM   #7
67Slider
67Slider's Avatar
18 Gallons
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 01-05-2011, 12:09 PM   #8
Critter
Future TOTM Winner
Critter's Avatar
The only thing I might do different is the license plate door. It looks like you have the spring loaded one that when you let go would pop back up. Some models have a break-over point so that once opened they stay in that position until you nudge them back closed. I forget the exact model of car but I pulled a couple on my last junk yard trip. Might make filling up a little easier for you.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline
Old 01-07-2011, 09:09 PM   #9
67Slider
67Slider's Avatar
Ok Guys. I went to the yard today and picked up a new license plate holder. It came off a 92 Caprice (old cop car). Works awesome. Thanks for the heads up on this one. Here are some pics and a shot of the tank from up my driveway and from the side.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 02-12-2011, 09:11 PM   #10
big d's red67
big d's red67's Avatar
This looks like an awsome mod, can you show more detail on how you fabed up the straps?
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline
Old 02-12-2011, 09:22 PM   #11
67Slider
67Slider's Avatar
The straps were the hardest part for me. I just laid the tank down and made bends in the strapping until they were right. Took a bit of trial and error but turned out good. Once I got the bends right I shot a coat of paint on them. No worries.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 02-13-2011, 12:06 AM   #12
67Slider
67Slider's Avatar
I finished my 3/5 drop today and toook a pic of the rearend. Sits nice and still looks pretty clean.
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 09-25-2010, 04:54 PM   #13
69 Okie Truck
69 Okie Truck's Avatar
How well does it fill?
69 Okie Truck is offline
Old 09-25-2010, 05:25 PM   #14
67Slider
67Slider's Avatar
Just filled it and it fills great.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 09-25-2010, 06:18 PM   #15
67Slider
67Slider's Avatar
Originally Posted by Kidd-7 View Post
Thats sweet; I grew up with a '79 TA in the family and thought that was the coolest thing at the gas pump. I have another idea to add to the list . Any concern with ground clearance it looks kinda low. What is the ride height of your truck? Thanks.
I have a 4 inch drop in the back. Doesn't sit any lower than the pumkin.
No leaks!
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 09-29-2010, 06:36 PM   #16
Bad70sbchevy
Bad70sbchevy's Avatar
I got some pics of the back of mine with stock lift.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline
Old 10-05-2010, 01:49 PM   #17
FL71C10
Nice build and info, guys. Any reason this wouldn't work on a stepside?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline
Old 10-29-2010, 07:27 PM   #18
swamp rat
swamp rat's Avatar
Originally Posted by GMCBubba View Post
i'm assuming that this type of gas tank relocation would not allow the use of a trailer hitch like this (http://sitepro12.sitepro.com/masterl..._13028_INS.pdf). what do you think?
Any tank would have to fit between the rails for it to work with a hitch.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline
Old 01-05-2011, 06:02 PM   #19
Critter
Future TOTM Winner
Critter's Avatar
If I remember right they were from a mid to late 80s Caprice, Pontiac Parisienne, Olds Delta 88, etc. I am positive they were from GM sedans at very least. Here are some pics. Notice how the hinge breaks over and stays in place. They could be mounted up or down. I plan to use mine for hidden hitch purposes. Incidentally, these pics are of the backside, the license plate side is face down.
Critter is offline
Old 01-06-2011, 01:16 PM   #20
tolly4503
I had a '90 Cadillac Fleetwood brougham, the fullsize caddy. it had the flip down plate holder that held itself down. They made those cars til '92.
tolly4503 is offline
Closed Thread
