Big Block Intake Gasket Block Off Plates
I will be installing an Edelbrock RPM intake on a 396 Big Block this weekend, and I would like to get opinions on whether to install the metal heat block-off plates that come with my intake gasket set.
I believe they are used if you want to eliminate the heat passages through the intake. I don't live in an extremely cold climate, and was wondering whether there are advantages to leaving the plates out, or if I need to use them? Thanks, guys. NoNeck
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. Last edited by NoNeck; 03-18-2011 at 09:57 AM. |
My Carbon Footprint
Re: Big Block Intake Gasket Block Off Plates
I never use them and it's my understanding that over time they will burn out anyways.
I just used one cuz I couldn't decide! I think they'll burn out too.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
