05-17-2011, 07:58 PM | #1 |
My Drop doesn't seem right
I have a 2.5/4 early classic drop kit on my truck. But it seems to be sitting a little higher compared to other trucks I see on the site. Maybe I'm just wanting to go lower and it is affecting my vision?
Any opinions? Can someone give me a measurement so I can compare to mine?
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e) 1990 K1500 Daily |
05-17-2011, 08:02 PM | #2 |
Re: My Drop doesn't seem right
It will take a little while for everything to settle.
05-17-2011, 08:05 PM | #3 |
i have the same drop mine did'nt need to settle looks about the same matbe a little higher in the back
05-17-2011, 08:16 PM | #4 |
Its been assembled for about a year. That should be long enough I would think.
05-17-2011, 08:53 PM | #5 |
Active Member
Do you have leaf springs in the back? They tend to sit higher than the coil springs and may be what you are noticing.
I lowered my 68 a couple of inches in the front and for the back removed three leaf springs (I had 8). As you can see the rear is still a little higher than I like. May have to go with lowered leaf springs. [IMG][/IMG] |
05-17-2011, 09:46 PM | #6 |
They are coils.
Does anyone have a measurement from their 4 inch rear drop? Rear axle hub to the bottom of the rear fender would give me an idea if I have a issue.
05-17-2011, 09:58 PM | #7 |
what size are your tires
05-18-2011, 01:24 AM | #8 |
Here is mine with a 2.5 front and 4 rear drop. I have 255/60R/15 tires in the front and it measures 28.5 inches to the top of the wheel well opening. Out back I have 275/60R/15 and it measures 29.5 inches, this is with coils. Hope this helps.
"If you need to tell everyone how good you are - your probably not" Last edited by Frank71; 05-18-2011 at 01:25 AM. |
05-18-2011, 01:25 AM | #9 |
GM Addicted
add a block in the rear and call it good man. level it out. Nice truck by the way
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
05-18-2011, 09:35 AM | #10 |
It's entirely possible they sent you the wrong springs, wouldn't be the first time that has happened from a vendor and since they don't have a big flag on them that says 4" it would be very easy to mix up.
My 4" sat quite a bit lower in the rear, sorry no measurements.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
05-19-2011, 10:58 AM | #11 |
Hey jackl,
I just put a 4/6 drop on my truck, but I had a 2/4 that the PO installed. My measurements were right at 30" front and rear from the ground to the bottom middle of the wheel arch. Also that was with a 255/70 tire (29"). Good luck |
05-19-2011, 11:45 AM | #12 |
you are also probably "visually" comparing how the truck sat before the change with 40 year old springs ... the new 4" springs are based on 4" lower than new stock springs. 40 year old springs will have some collapse or "settling" from age therefore you may not get a true 4" of lowering from where it was with the old springs.
hope that makes sense .... |
05-19-2011, 07:22 PM | #13 |
It is actually higher than it was than with my original springs that were worn out.
Can you use a lowering block on a coil spring suspension? I hate to deal with pulling out the springs. Blocks look to be cheaper. Any suggestions?
05-21-2011, 03:37 PM | #14 | |
http://www.classicperform.com/goingdown6772.htm
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
05-21-2011, 08:03 AM | #15 |
I agree,that does look higher than normal
But you honestly probably want/need the 4/6 drop Posted via Mobile Device
Best Regards, Leon 1970 C/10 LWB Cummins Turbo - Build in Progress Many other toys as well... |
05-21-2011, 03:31 PM | #16 |
Here is the truck I gave my son. Same drop as yours. Parts from the same Company.
05-21-2011, 05:50 PM | #17 |
I'm gonna throw a set of blocks on it. (2 inch)
I am starting to believe I have the wrong springs from ece. But it had been several years since I bought them. I will not even attempt to pursue returning them. Mistakes happen. I will see what it looks like using the blocks and go from there. Posted via Mobile Device
05-23-2011, 01:38 PM | #18 |
grs,
What size wheels are those on your sons truck? I like the look of those wheels. |
05-23-2011, 09:01 PM | #19 |
My wheels are 22 inch Coys.
