How to tell outward difference in chevy 292 - 250 engine
We have located what we think is a 292 6 cyl chevy engine and transmission. How can we determine if the engine is a 292? We also want a 400 transmission.
Are there any markings or way of knowing for sure that they are a 292 and 400? Thanks Matt |
I am a Referee of life.
Re: How to tell outward difference in chevy 292 - 250 engine
The 292 engine has the tall side(lifter) covers.They are 6 in tall,250,230 194 are 4 in.The fuel pump is behind the Motor mount on the pass side of a 292.
I'm not much help on tranny's.My B-I-L is a tranny guy so I don't have to mess with them.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Sep 2003
Also if i recall there is space between the waterpump and the block deck on 292CI but not on the smaller I6 motors
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
To expand on what PanelDeland said, the motor mounts are off-set about 2 inches from each other. The pass side is further forward than the driver's side. As for the tranny's, I read some good advice here one time-a 350 tranny has more of a rectangle oil pan, while the 400's is shaped a little like Texas.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
A TH400 has an irregular shaped pan and the vacuum modulator is located on the right side of the transmission pointing torward the passenger side of the trans. The TH350 has a almost square pan with a angled notch, the vacuum module points toward the rear of the vehicle on the right side. Powerglides have square pans. Here is a link to see...http://www.roadkillcustoms.com/hot-r...tification.asp
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
member #16
![]() Join Date: Dec 1999
250-292 pics.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Great photos of the two 6 cyl engines ! Can anyone explain the difference in PCV setups for the 292 ? Why does it have the additional breather tube off the valve cover going to the air cleaner ? Does the 292 have an issue with blow by ? On my 292 I am only using one PCV from back of cover to port on intake, I am using a breather/ cap on the front of valve cover like on a 250. with this setup I am noticing a small amount of oil seeping out around side covers and back of valve cover ? bolts are tight...any help would be great...
71 C-20 07 Magnum RT AWD |
The breather cap on the valve cover is just a chunk of steel wool. Taking air from the air cleaner gives you cleaner air going into the crankcase. Steel wool only stops the big chunks.
During high load or WOT the PCV usually can't pull in all the blow-by, even on a perfectly health near new engine. The excess fumes go out the breather into the atmophere. When you have the connection to the air cleaner, the excess fumes go in above the carburetor and are consumed by the engine. The later is called a Closed PCV System and is the only type of PCV System that has been legal for the last 50 years. Check to see if you have a problem with your PCV valve. take the cap off and place the palm of your hand over the fill hole. You should feel a small amount of vacuum at idle. Pull the valve out and with the engine running put your finger over the hole in the valve. You should feel plenty of vacuum and you will hear the pindle snap to the wide open position. If you take it off, you should be able to blow air through it from the valve cover side, but not the vacuum source side. It should close up from that side if you have a back-fire in the carb or manifold. The PCV valve is listed as a regular maintenance item on all cars. It is supposed to be cleaned or checked almost as often as you change your oil. NO one does and they get gummed up.
'67 GMC 2500, 292, 4spd, AC Last edited by RichardJ; 03-26-2012 at 09:16 PM. |
#9 | |
1965 One Ton GMC 4x4 project Have 3 trucks in my photo album, building them into one custom but original looking 4x4 dually reg cab pickup with 133" wheel base. |
